Question about Microsoft Office XP Professional OEM w/ Publisher 2002 Bundle (M04-00245OEM) for PC
How do we reconnnect
Why was i disconnected and how do we reconnect without me having to pay again
  • 2 more comments
  • frank4277 May 16, 2008
    so can u answer my question on how we reconnect and if you rather not deal with the issue anymore how do i get another person involved?......can they read our information and I can go from there?
    ok awesome i will pay again knowing i will be reimbursed and find you......
    ok i tried what you suggested and when i press the end session buttoon it does not prompt you to another agent it ends the session so thaks i have wasted 4 hours and still did not get help.........i feel as if someone has stolen something from me
    i promised people that i would have this finished and today is my last day to do so and because i have wasted so much time i am in a worse position than before i used your service now i dont even have the last website up.........thanks for making my situation worse
  • Microsoft Master
  • 13,433 Answers
I've contacted you in another problem you posted with instructions on how to get refunded.
Posted on May 16, 2008
    Master:
  • 555 Answers
Yeah, I got to it first. frank4277 was none too pleased, and terminated the session when he realized I could not pick up where you left off (I cannot see your chat transcripts). What a system! :)
    President:
  • 2,712 Answers
Dont know how you go disconnected..must have been some issue with the fixya site.
Anyways, its real simple..Run the LeechFTP .zip program, you will see a setup.exe file. Double click that, and you will be able to launch Leechftp. Now click on the lightning icon (connect), selectt the loacal folder and enter all your ftp details. Once you get to the root directory, simply upload all your files that we just created. Or you can also use your regular web based FTP that you were using till now..
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson May 16, 2008
    you can start a new chat. You will not be charged for the first one. Send an email to premium.support@fixya.com, and they will refund you for the first chat. You can try to start a second chat, and if you dont see me, simply end session and rry again..
  • Swilin Sampson
    if you get a new person, you will have to explain all over again
  • Swilin Sampson
    Or tell you what..upload all the files either through leech or thru your regular ftp that you were using. Once you have done that, I will check the links and stuff, and if there is any problem, I will correct it.
    Make sure that you upload the files as they are, dont rename anything after you publish..
  • Swilin Sampson
    hopefully you will find me , unless some other expert get to it first :)
How do I get Fox News Channel without paying cable tv.
If you have cable internet you can get a splitter and run your chlamydia to both your modem and your tv. If you don't just go outside your house and reconnect the cable, just understand d that they do concider that theft, but the chances of them doing anything other thAn disconnecting it again are slim to none.
Mar 04, 2015 | Computers & Internet
My alarm goes off every time for no reason . i tried turning it on today n it doesnt wanna turn on -_-. can the alarm drain my battery?
Yes this can drain the battery eventually. Try disconnecting the battery (negative terminal) and reconnnect and see if this helps. If not you may have a wire issue. Maybe bad ground.
Jul 09, 2011 | Mazda RX-8 Cars & Trucks
~ 1991 STX38: Starter engages, engine cranks but won't start, when key is turned off, engine continues to crank. Disconnected battery to stop engine from cranking. Upon attempting to reconnnect battery...
The starter solenoid may be stuck in the on-position. To check this, on the starter, remove the small wire connected to the solenoid coil terminal. If the starter still runs, the solenoid is stuck on. If rapping it with a hammer doesn't stop it, the contactor pin is welded to the motor contacts.
Jul 02, 2017 | John Deere Garden
Hose to rear windshield washer keeps coming loose. i pay each time to have it reconnected. trying to reconnect it myself this time. cannot locate where it connects
If you keep going to the same dealer to get this repaired and it keeps coming apart I would find a different dealer to repair the problem. I certainly wouldn't be paying them repeatedly for the same repair.It most likely attaches to a connection on the wiper itself. The only reason for it to keep disconnecting itself is the line is too short or someone is messing with you. Without looking at the connection itself I can only recommend that you get the Haynes repair Manual for your vehicle. This will show you the connection and how to properly route the connection so this problem doesn't persist. It won't cost as much as having the Shop repair it repeatedly.
Jun 18, 2010 | 2001 GMC Yukon XL
System not booting, k8n
Have you tried resetting the bios? turn off the computer and remove the power cable connected to the power ATX power supply, look for the "clr_cmos" jumper and change the settings from 1-2 to 2-3 for approx. 10 secs, then return the jumpers to original settings and reconnnect the power cable and turn on the computer. This was the solution when i had the same problem before. Hope this helps you too.
Oct 01, 2009 | ASUS K8N-E Motherboard
I recently changed my passcode on my ipod touch but i can not remember my passcode how can i unlock it without having to pay?
you can reset its password....but you'll lose all your data. Here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Sep 05, 2009 | Apple iPod touch
Error: 0xf0af8004
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Mar 26, 2009 | HP Officejet 5510 All-In-One Thermal...
Reparing a kitchen faucet hose
Hi foxyroxy1494,
I'm Harvey the Master Plumber.
Your problem is: How do you reconnect the handle to the hose? It seems like there is a connector piece missing. If you just reconnnect it, its very difficult.
Is this the type of faucet with the sprayer handle as part of the faucet spout? If so, it just screws on.
Is this the type of faucet with the sprayer handle next to the faucet? If so, It's important that you didn't loose the tiny C clip. When you took it apart you had to unscrew the handle from the base and remove the C clip from the hose to remove the base. If you have all the parts just reverse the process. And yes it can be more dificult than it looks.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 03, 2008 | Plumbing
Microsoft Office XP Professional OEM w/ Publisher 2002 Bundle (M04-00245OEM) for PC Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
