Question about Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
Seat back won't lock - Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
  • 692 Answers
JC If your chair is an Invacare locate The lever on the right side of the lower seat cushion that lets you adjust the seat back it might be stuck letting the seat back not lock. Try setting the back where you want it and pushing down on the handle to see if you can get it to lock. If you can't get it to lock you'll just hafta get another seat or find a used seat that you can take the locking lever off of. Hope this helps
Posted on Sep 15, 2010
Seat back won't stay up
Probably has a broken or jammed lock When you position the seat try pulling/pushing the handle instead of relying on the spring to engage the lock. If the seat frame is broken remove it for repair or replace with another seat back
Feb 22, 2013 | 1998 Toyota Corolla
2001 accord rear seat back won't fold down
Have you tired spraying some dry lock cylinder lube into the key opening to free top the lock? try that and see if that works if not you will need a locksmith to change the key cylinder or remove it. Do not use anything like WD40 Us dry spray in Graphite powder lock lube.
Aug 06, 2012 | Honda Cars & Trucks
The larger passenger seat won't lock
Be sure to inspect and clean the complete seat track, especially the locking lever. Hope this helps.
Jul 12, 2012 | 2002 Ford Excursion
Passenger seat won't lock in place
The adjusting lever for seat position is not locking into place. On the bottom of seat are runners on each side with holes in them that the adjusting lever tabs will lock in and hold seat in place. The seat slides on the runners if those tabs are raised. There is also a connecting wire or rod from the lever to the other side of seat so when lever is pulled up, tabs on both runners are raised for seat to slide. Something is keeping the tabs from locking into the holes on the runners in your car. Maybe the adjusting lever is broken somewhere, or the wire/rod came loose, or the lever is just dry and sticky and needs a shot of WD40 to loosen it up. If you can't see it and fix it with seat in place, then pull the seat back off for the repair. Good luck. Post back if my explanatiopn is not clear or you still need help.
Jun 19, 2012 | 1998 BMW Z3 Roadster
My trunk won't open
hi some models do have fold down seats, but if yours does you would know, if you have to get into the boot to manually open the lock remove the lower back seat by 2bolts near floor level, then the upper seat by 2 or 3 bolts that will now be exposed, then simply lift out
Apr 06, 2012 | 1999 Subaru Impreza
Back seats won't fold down 97 toyota camry
The plastic pull on the top of the seat may have been screwed down too much. If that happens, it will not allowing the lock mechanism to fully unlock. Unscrew the top plastic pull a little at a time and at the same time reach around and pull the lock leaver up until it is in the full unlock position. You should then be able to pull the plastic lever up normally and fold down the seat.
Nov 08, 2011 | 1997 Toyota Camry
Iv been given a bugaboo cameleon from interstate and it won't open ? and the seat is also attached now ..and I can't get it off .'it was made in 2005. Thank you .
Frame won't open with seat attached and the seat should not fit on a closed frame? The seat is the locking component for the frame. Someone has used brute force to get it like that and it'll take brute force to undo the damage. Get a can of silicon spray and lubricate the seat locks and turn stroller upside down to get some to run down inside the seat legs. Press both square seat release buttons inward (one side has a small safety lock you heed to side across before you push inward) and heave up! You cant do any more damage than what may have been done. Click here to see the correct way to set up your stroller.www.fixya.com/support/r9134331-assemble_frog_or_cameleon
Jul 26, 2011 | Bugaboo 'Cameleon' Stroller
2004 3rd row rear seat won't fold down using lever
Cable is broken or stretched. pick up the bottom seat and see the cable end if broken or slack from being stretched pull that cable and then the back should fold down. Ibelieve you will need to remove seat to repair the cable. the bottom seat when lifted pulls on a cable that releases the backs lock to fold down
Jun 11, 2011 | 2004 Chevrolet Suburban
My 98 srad has a single seat cowel,how do iremove to fit seat,removed both side retaining bolts but still won`t com e off
Use the ignition key for the lock under where the back seat goes, right above the chain. turn the key in the lock and pull up on the cowl, it will come right off, then you can pop the rear pillion "backseat" into it's place
Aug 16, 2010 | 1998 Suzuki GSX-R 600
Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Logo
78 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
