Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
REMOVING FLITER ON A HOTPOINT WD420
UNABLE TO REMOVE THE FILTER ON WASHING MACHINE
The filter is inside the machine. If you machine is still under guarantee I would try and get it done that way. Otherwise turn off the power and pull out the machine to get a the back.
Remove the panel at the bottom where the discharge hose comes out. You should see a black concertina type tube coming from the drum attached by a jubillee clip. THe filter is inside. Losen the clip and pull away the tube take out the filter and clean it. When you replace it don't forget to put the ball float back in and check its well fixed by runing a spin cycle before sealing up.
Posted on Aug 29, 2008
There isn't one
Posted on Aug 16, 2008
Where is the filter on a Hotpoint Aquarius wd420 washer dryer?
it is located at the back of the machine...are you encountering problems with this machine? check this link i will give you, this a forum/comments which the owners encountered different problems with this machine..
http://www.unbeatable.co.uk/p_rupr/Hotpoint-Aquarius-WD420-Front-Load-All-in-One-Washer--Dryer-Reviews/22394331.html
Nov 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
I have a hotpoint wd420. the door light is flashing the wash light is on constant and the machine wont work anyone any solutions please!!
My WD 420 packed up, after watching the blogs I did:1) remove filter - found 2 quid, a thong, a pop sock, a christmas cracker toy and a load of gunge. 2) removed the motor - brushes worn to nothing - replaced them.
Washer running as new. 6 years old, 2 house moves - not bad reliability. Nearly gave up and bought a new machine!!
Nov 11, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Machine very noisy when it spins. Missing bra
If you cannot here it catching, then leave well alone, if it is still catching, then you could to try to locate it by removing the lower rear cover of washer, remove the large black hose on bottom of drum, and see if you can locate it from the bottom of the drum.
Hope this helps.
Jan 16, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Feb 08, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Removal of door seal on hotpoint washer drier wd420
You will achieve nothing by removing the door seal .
Depending what is in there, better to leave alone and trust it will find its way into the filter.
If it is anything substantial then it involves major work.
Dec 14, 2008 | Hotpoint Aquarius WD640 Front Load...
How do i check the filter on a hotpoint washing machine
no filter but pump may be plugged remove front panel pump om right side ..to remove panel putty knife press hidden clips under front edge and pull panel forward
May 27, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
333 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
