Question about Quartet gbc 3260X Shredder
HELP, MY GBC SHREDMASTER 3260X QUIT SHREDDING. THE GEARS WORK WHEN YOU REVERSE BUT NOT WHEN YOU WANT IT TO GO FORWARD AND SHRED. WHAT COULD BE THE PROBLEM. I APPRECIATE YOUR HELP. TXS.
3 Suggested Answers
fellowesrep
  • 102 Answers
SOURCE: Hello, I have a GBC Shredmaster 6120S
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc board has gone bad and you will have to contact your manufacturer for further parts availability.
Posted on Mar 02, 2008
  • 3 Answers
SOURCE: How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
Posted on May 27, 2009
Powered off during shred.
some shredders have overheat protection. see your manual or wait an hour and try again.
Jan 02, 2011 | Quartet gbc Shredmaster 4500S Shredder
Cannot get it shred forward or reverse. Is there a reset or fuse Paper shredder
probably has broken gears. Aurora does not produce replacement parts for any of their machines. Actually made by Royal and they don't make parts either so don't buy either brand.I guess Fellows is about the best brand or GBC.
Nov 13, 2009 | Memorex Paper Shredder
How do you set it to continually shred. We used
Blow some canned air into the feed slot clean the sensors
Nov 05, 2009 | Quartet gbc Shredmaster 5550X Confetti-Cut...
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
Paper shredder
There is a housing arond the shredding wheels, they get jamed with paer and break the screws holding this guard around the wheels. Not sure on that model if it has those gray plastic guards, and they are available...
Jun 21, 2008 | Office Equipment & Supplies
Automatic Shredding
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Dec 10, 2007 | Quartet gbc Shredmaster 2240S (Strip-Cut)...
Oct 02, 2007 | Office Equipment & Supplies
My shredder stop shredding. has paper caught in itposted
You must have a stripped gear. Should be a number in op manual. Take the top cover off and look for the broken gear. Call them an order gear.
Aug 30, 2007 | Quartet gbc 6120S Shredder
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Aug 29, 2007 | Quartet gbc 6120S Shredder
Quartet gbc 3260X Shredder Logo
201 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pie-man
Level 1 Expert
Bill Boyd
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
