Question about Microsoft Windows Vista Ultimate Edition
Godspeed ebook where can i find a copy of vista usb drivers that will allow me to run emos version 3.2.0 build 14?
  • 43 Answers
U can go such sites as following:
www.driversplanet.com
www.drivers.com
www.download.com
and so more............
Posted on May 17, 2008
Remove wat could not solve my window is not genuine build 7600 problem give me another aolution
Windows 7 Build 7600 by default will not allow you to do an upgrade install.
This how to will describe the process needed to upgrade from Windows 7 Build 7100 to Windows 7 Build 7600 with out doing a clean install.
Download the ISO as you did previously and burn the ISO to a DVD.
Copy the whole image to a storage location you wish to run the upgrade from (a bootable flash drive or a directory on any partition on the machine running the pre-release build).
Open the file cversion.ini in a text editor like Notepad
Modify the MinClient build number to a value of 7100.0
Save the file in place with the same name
Run setup like you would normally from this modified copy of the image and the version check will be bypassed.
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB.
You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://100-downloads.com/publisher.php?pb=http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool&dl=727
http://download.cnet.com/windows-7-usb-dvd/3000-18513_4-10972600.html
Create a copy of your Windows 7 ISO file on removable media
Sep 27, 2013 | Compaq Presario CQ62-209WM Athlon II X2...
Phaser 8500 - cannot print color under 64-bit Win 7
to start from the beginning, i understand that you are running win7/64bit, usb connected. on base of this assumption we will try to solve your problem. by the way, i love this printer!
1. disconnect printer from usb port,
2. remove all instances of your printer and printer driver from your computer, run ccleaner to clean the junk including registry
3. download again your printer driver (it should be about 6.3mb, lite version which you most probably downloaded will not work!), just in case if previous download was corrupted, choose global english as a lingo.
4. http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=8500_8550&ripId=&Xtype=download
5. unzip file to root directory or desktop, anywhere where you can find them easy.
6. connect your printer to the computer
7. right mouse click on "my computer"
8. left mouse click on "control panel home"
9. under "hardware and sound" left click on "view devices and printers", your printer should be there
10. 2x left click on the printer
11. 2x left click on "customize your printer"
12. left click on "advanced" tab
13 select "new driver"
14. select "have disk" and point search where you did unfold the drivers.
as this particular printer is part of build in microsoft printers, often microsoft is overriding your preferences and this process will allow you to use manufacturers settings not a microsoft.
after this your printer should be visible in printer folder as default. make test print,
if you find this solution useful, please do not hesitate to leave feedback and vote4 for me, if you do require additional help, please call back.
Aug 02, 2010 | Xerox Phaser 8500/8550 All-In-One Thermal...
I Need Windows XP Drivers for Sony VAIO VGN-NS10L/S Laptop
Good day!!! I know the link for the VGN series for windows XP drivers you can download the drivers there ( http://www.getpcmemory.com/drivers/download-sony-vaio-vgn-series-notebooks-windows-xp-drivers/ ) hope this one can solve your problem.Cheers and God Bless.
Jun 23, 2009 | HP LaserJet P2015 Printer
Cant put ebook or movies on it
Just drag files from Windows Explorer to device make sure that when you open up device that there are the categories: music, pictures, video, playlist. Drag video to video on device, drag ebooks to playlist. Also, confirm this with Coby Media Manager.
Apr 30, 2009 | Coby MP-705 Digital Media Player
Trekstor 74412 i.Beat emo 2 GB MP3 Player
Try this , plug in usb cord into the emo, simultaneously push the small reset button at the lower right corner under the power button , if that doesnt work here's the link for the xp drivers
http://www.trekstor.de/downloads/produkte/i-beat_emo/driver-tools-win-all_i-beat_emo_v2-620-013_all.zip
(copy and paste )
hope this helps :)
Dec 29, 2008 | Trekstor 74412 i.Beat emo MP3 Player
Won't turn on; won't turn off
The video may be glitched or the memory is full. Try unlocking the unit by pressing the reset button with a paperclip. It's located just below the on/off switch on the right side.
Nov 29, 2008 | Trekstor 74412 i.Beat emo MP3 Player
Charging issues
Emo can only be charged by your computers usb 2.0 port. Independent chargers did not appear to work. I was manager and owner of a computer business. The independent USB Universal Serial Bus 2.0 chargers might work but the emo recognizes the computer and navigates to the charge screen when charging but when using an USB charger (less than $10) the emo won't go to that screen however there is no evidence that it isn't charging.
Oct 09, 2008 | Trekstor 74412 i.Beat emo MP3 Player
Downloading music onto the jazz dv 150 from my computer.
Try not running the Syn software at all. Try copying the files over manually.
After plugging in the USB cable you should get a small popup that says its connected.
Click on "My computer" and under "Devices with removable storage" you should see a new device called DV.
double click on that and you should see 3 folders. DCIM, EBOOK, and MP3
Copy your mp3 files from your computer into the mp3 folder of the camera and it should work.
Mar 26, 2008 | Jazz DV150 Camcorder
Code 10 Error
Issues: Code 10 error, Physical Memory is 2GB +
1. Go to http://www.station-drivers.com/page/marvell.htm
and download the Marvell Libertas driver Version 1.0.0.53 date: 10/16/2007
2. Run the self-extracting Zip file to uncompress the driver files
3. Under driver\inf\Vista...\32BITS there is a file called "netmw13b". Copy this file to c:\windows\system32\drivers, overwriting the file that is currently there
4. Reboot Vista
There. Four easy steps. Someone please give this a try and let us know whether it's really that simple.
Notes...
32 bit Vista SP1 will install a May '07 driver which will not allow more than 2Gb RAM .Run InvokeSetup after extracting and v. 1.0.0.53 of the driver will be installed. After doing this I added 2GB more RAM (4GB total) and everything works.
Jan 18, 2008 | NetGear - WG311 - 54Mbps 802.11g/b...
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
