Question about Dryers
I have a kenmore stackable washer and dryer. model number 417.947023300 It was making a sever screeching noise, then it went thud and qiut.I have checked the belt and it works fine, I have turned the drum and it turns. When i go to turn it on you can hear the motor trying to run but won't I am stumped. I see no weels that go to drum. just the belt line. Some one please help me fix this.A digram would also be helpful.
  • Dryers Master
  • 19,396 Answers
Hi.
If we are talking about the dryer, then the high pitched noise could have been caused by the belt slipping on a seized motor, or for example by a defective blower wheel. There are also a number of mechanic troubles that could have caused high pitched noise.
If the motor is trying to start but does not run, then the motor is probably shot. The motor is tested by jumping contacts and energizing it directly.
Other parts failure may have caused overheating, the thermostats and thermal light must also be tested.
Here all parts and diagrams, including wiring diagram.
Posted on Sep 15, 2010
My dryer is a model number GLER341AS2 and when I turn it on it makes a sreeching noise. Now the screeching has turned into a louder noise almost like a rubbing thud.
The symptoms you describe indicate that your dryer drum bearings are faulty: there is usually a large 'felt' bearing around the opening which support the drum and prevent metal to metal contact (screeching noises)- The drum must be removed to get to this front bearing (which is normally glue to the dryer front panel at the drum opening): it is not a trivial job and is not normally replaceable by end-users.
Hope the explanation helps.
Sep 23, 2011 | Frigidaire Dryers
I have a frigidaire stackable washer/dryer model number FEx831cs0. The washer is working just find but the dryer for a few weeks has been making the worst screeching sounding in the world. I am not sure if...
A loose belt often makes a squeak that pulsates with the clothes hitting the paddles in the drum. It's probably the upper drum glide or rear bearing. If it's a constant screech coming from the front, it's probably the glide. If the noise seems to be in the back, suspect the bearing. You might check for a sock or something small that is stuck somewhere between the drum and the dryer.
Glide: http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/916658?modelNumber=FEX831CS0
Bearing kit: http://www.repairclinic.com/PartDetail/Drum-Bearing-Kit/1851?modelNumber=FEX831CS0
Neither are very difficult to repair.
Other parts for your machine:
http://www.repairclinic.com/Shop-For-Parts?s=t-%20FEX831CS%20-%3d%3d
Good luck.
Feb 28, 2011 | Frigidaire FEX831CS Top Load Stacked...
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable dryer makes thumping noises -think its a broken belt
9 out of 10 times this is due to a bad roller. This is not something you can do yourself. A stack model is just too complicated.
Jun 09, 2009 | Kenmore 84052 Dryer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
