How to connect front panel USB pins into motherbroad(RED, GREEN, WHITE and BLACK)and where? thanks
    Master:
    Sergeant:
  • 460 Answers
It is mark on motherboard.
Posted on Sep 15, 2010
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1984 - 1987 Honda Civic...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1984
1985
1986
1987
STEREO WIRING COLOR CHART:
Constant 12V+: White/Blue
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness:
1984, 1985:70-1388
1986, 1987:70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
I HAVE A NEW CASE, & NEED TO CONNECT THE FRONT UBB & AUDIO LEADS. CAN YOU HELP, CHEERS
Hi there, first check the image below. You've got USB 3 and 4, and AUDIO section. For the USB, pins 1 and 2 represent front panel USB power on both 3 and 4. As for AUDIO connection, pin 1 is Front Panel Microphone input signal, pin 3 is Microphone Power, pins 5 and 6 are for Right Channel audio signal to Front Panel and pins 9 and 10 are for Left Channel audio signal to Front Panel.
You can find more details in the motherboard's manual, page 23 and 24.
Jan 23, 2011 | EliteGroup P4M800PRO-M478 Motherboard
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
ASUSP4SD-VX Can not figure out how to configure plug for front USB panel to motherboard, when using this mothervoard in a generic case.
your motherboard only supports USB v1.1, make sure those are they type of connectors on your case, and if so, open this document and go to page 2-16 for diagram: http://dlcdnas.asus.com/pub/ASUS/mb/sock478/p4sdr-vm/e1104_p4sdr-vm.pdf
if the case only has USB v2.0 plugs, you cannot connect them.
Jun 28, 2009 | Computers & Internet
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Would like to find the pin sequence for the
black green white red inside row nearest battery,starting from the front facing end.
Mar 13, 2009 | Gigabyte GA-8SIML Motherboard
Soltek SL-75FRN2-L front pannel connecting
The USB header on the MOBO is an 8 or 10 pin in a 2X4 or 2X5 orientation. there will be one pin missing, that is not unusual. the plug will have the same socket filled. Most MOBOs have multiple USB headers on it and they are almost aleays labeled USB2 or whatever number.
May 19, 2008 | Soltek SL-75FRN2-L Motherboard
VIA Technologies, Inc. PC Model KM400-8235
Probably the cables your are referring to are the front bezel USB and Audio Panel connector .If you do not use front USB port on your cab leave it NC .
Apr 28, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Usb not working
front USB ports are an extension of a header on the mainboard, it connects via a bunch on individual pins, if any of these pins are wrong the front USB will not work, but usually this would lock up all USB and the ones on the back will not work either, i would suggest the front USB panel was either not connected at all, or it was conected wrong, usual USB header colors of wores is BLACK, GREEN, WHITE, RED, note all mainboards are different, so the black could start from either side of the header, b sure to refer to your motherboards manual for exact pin loactions on the header
Dec 05, 2007 | Gigabyte GA-945GM-S2 (0818313003065)...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
