Question about Logitech QuickCam Pro 5000 Webcam
Multiple screen coming up in black and white also flickering on and off
The screen splits in 4 images side by side also flickers to one image how do i fix this?thanks anna
  • 1 more comment
  • sniperpaddy Jun 28, 2008
    same here. some have suggested it is a driver issue with SiS video chipset.
  • watoto22 Aug 11, 2008
    Ughhh I just bought a Logitech and it's doing the same thing! There is just 4 multiple shot's side by side which are black and white. A few seconds later it will go to one clear image and then go back to 4 shot's again! What is wrong?? :(
  • spirospero Aug 28, 2008
    Same problem: 4 black & white images instead of 1 colour image.
    webcam: logitech quickcame3500
    I found this fix on the logitech site.
    Go to Start>Run, type "dxdiag", wait for the application to show, then go to the "Display" tab and disable Direct3D acceleration or Directdraw acceleration. Exit. That's all.
    I tried it & it worked a treat.
I have a logitech quickcam E3500
I have 4 black & white images
I tried downloading older and newer versions of the software, no joy.
From the logitech site, I found this fix:
I tried it and it works a treat.
Posted on Aug 28, 2008
Mitsubishi flickering white lights on screen
this sounds like a bad optical light engine, the spots will only continue to grow in number.
See typical engine for this brand, lens on left is where image comes out and is directed on the screen.
Dec 22, 2012 | Mitsubishi WD-65733 65" HDTV
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
50" Toshiba Plasma screen is flashing with flickering sound
www.tacp.toshiba.com/tacpassets-images/.../42hp66_om_e.pdf
http://www.fixdevice.com/smanuals/file/31149.html
Above, download these Service manuals, it will show you how to troubleshoot, and identify what board to repair change.
May 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
White and purple flickering vertical lines. No image or sound.
I Hope this helps!
Sony has extended the Warranty for people experiencing picture anomalies due to LCD Panel failure through October 31, 2012.
See here:
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 04, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
Nov 18, 2009 | Computers & Internet
Flickering and screen dark
sounds like the lamp on one side of the monitor is going out.
It is repairable depending on how tech savy you are.
Sep 03, 2009 | Computers & Internet
The screen on my packard bell laptop flickers. It is approx 1 year old. This happens if it has been on a while or has just powered up, when plugged in or running on battery regardless of what it is being...
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | Packard Bell Easy One Silver 2120 Notebook
TV has multiple images and flickers, images are not centered and different sizes? What is wrong?
Multiple image is usually a result of transmission problem. The signal from your local station gets transmitted two ways, by tower and cable. If the tv receives them both at seperate times it will create an overlap or shadow effect. I would try a small power booster on it, if not a service man may have to adjust the internal circuits.
Mar 07, 2008 | Zenith B32A24Z 32" TV
Flickering and freezing of picture for a split second
The most likely problem for image problems and flickering is the lamp (23311083A). I found it at PartStore.com for about $180. Hope this helps.
Nov 11, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
The image projected from my CTX EzPro 680 Projector flickers on screen
From my experiences working with projectors, more than likely you will need to replace the lamp
Oct 04, 2007 | CTX Optoma EzPro 680 Multimedia Projector
Logitech QuickCam Pro 5000 Webcam Logo
488 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
