Question about Omron Healthcare Omron D4mb-s100 Switch
Good morning. I need the replacement switch for the Omron switch p/n: D4MB-S100. Omron indicated that this switch is obsolete. Thank you.
The door switch has failed and must be replaced. the switch information is OMRON RE2 1054H5 C-15G-3C25 15A 1/2HP 125 250 VAC 0.1A 125 VDC. Is there a place somewhere that I can order this switch from?...
In Canada B & E industrial electronics (Calgary) carries the switches typically used for microwave doors (~$5). Reliable parts carries the whole assembly of 3 switches and the plastic interlock housing for about $25. Probably worth calling your local industrial electronics supplier. Never purchased online but should be available from any online electronics reseller. Honeywell is another manufacturer (see Microswitches)... HONEYWELL HIGH FORCE PIN PLUNGER 15A Part # V71C17D8
Allied Electronics Online (US) carries the same switch which is interchangable with yours. Honeywell / MicroswitchSwitch, Miniature, Basic, SPDT, PIN PLUNGER Actuator, QUICK CONNECT TERMINATION
(Are you getting all these numbers off the switch itself as the OMRON RE2 sounds a bit like a relay number...?)
Oct 21, 2010 | Panasonic NN-S954WF Microwave Oven
Where is omron bp monitor service center in india my bp monitor doesnot get enough preesure and shows no 50 on the screen.
call rehman on mobile no: +91-8754414889 for all your query of omron or other make of blood pressure monitor service problems
Jan 19, 2010 | Omron Automatic Blood Pressure Monitor...
I have an Omron 705IT BP machine with printer. I can't find any details in the instruction book of how to clear the memory to prevent old readings being printed. Can you help?
Please follow the below link for instruction book -
http://www.midmeds.co.uk/images/datasheets%20and%20extra%20info/omron%20705it%20manual.pdf
Just copy and past the above link to your web browser....
Good Luck!!
Thanks
Oct 16, 2009 | Omron Blood Pressure Monitor Hem 775...
How do I clear the memory
Select ID (A or B), press+hold for more that 2 sec both buttons: START & MEMORY.
Jun 10, 2009 | Omron Blood Pressure Monitor Hem 775...
OMRON RS4602 EPOS - CG file full, cannot clear screen and cant find any info anywhere about how to, any ideas?
Some Omron cash register manuals here too:
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
omron RS-3010E Programming
omron RS-3010 User(R) Service(R) Programming(R)
omron RS-3410 User(R) Programming(R)
omron RS-3460 Programming(R)
omron RS-4601 Programming(R)
omron RS18 Programming(R)
omron RS25 Managers guide(R) Programming(R)
Jan 02, 2009 | Omron Hj 720ITC Advanced Pocket Pedometer
I am trying to fix a Sharp 27k-s100 television.
Can you use the remote control to change the channels? If not, it may be that to need to reprogram the remote to work with your TV. I just had the same problem. I have GE universal remote and have reprogrammed it to work with my SHARP 27k-s100 TV by following these instructions: http://www.ehow.com/how_9190_program-ge-universal.html The code that worked for my TV is 173. Other codes listed for SHARP are: 004, 006, 012, 029, 095, 111, 112, 113, 122, 171. Good luck!
Sep 11, 2007 | Sharp 27K-S100 TV
Omron Healthcare Omron D4mb-s100 Switch  Logo
87 people viewed this question
Top Omron Healthcare Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Omron Healthcare Electrical Supply Expert? Answer questions, earn points and help others
