Question about Traulsen 46 cu. ft. Commercial Freezer G22001
The freezer acts as if it is going to start, but then it doesn't. the fan inside is running, but the temp is up to over 40 degrees
    Sergeant:
    Novelist:
  • 193 Answers
When a compressor is burned out it will try to start and then quickly overheat and kick out on the safety. Listen closely to the fans when the compressor tries to start. A bad compressor will pull so many amps that the fans will actually slow down until you hear the click, then the fans will pick up speed again. If this is the case you will need a replacement compressor. Let me know how long it takes to click out when it tries to start.
Posted on Sep 15, 2010
Our Freezer is not running correctly and is staying at a temperature of about 40 degrees. The temperature display reads REC. Please help. Thanks
REC means recovery. It is trying to make temp and is not. Could be frozen up evap, no fan running, door not closing, issues with the refrigeration system.
Jun 19, 2015 | Hoshizaki Commercial Freezer SafeTemp®...
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Freezer control is on the highest setting and the inside temp is 40 degrees and most the food is thawed. what could be wrong?
you may have a bad compressor.also need to check the evaporator fan and see if it is turning. do you have any kind of frost build up on the back wall that you can see.the fan is located behind the rear panel in the back of the freezer if you your it running you may have a bad compressor
Sep 24, 2009 | Frigidaire 16.7 cu. ft. / 473 liter...
Beverage-Air KF48-1AS not coooling, fans not running
some thing wrong with the evaporator fan motor. make sure the motor turns freely. your going to need service .
Jun 19, 2009 | Carrier 44.9 cu. ft. Upright Freezer...
I have an older commercial upright Hobart freezer. The freezer seems to operate fine, cycling but always returning the compartment to zero degrees, until all of a sudden the temperature went up, well...
In most cases, an evap that freezes up is either an air flow problem or no defrost cycle. Older Hobarts have mechanical defrost time clocks. It could be locked up i.e., not running so no defrost cycle.
It could be coming out of defrost too early because the sensor that monitors the evap temp is not working properly.
The door could not be closing. If left cracked open, it will freeze up every time as unit never hits temp., keeps unit running. Warm air is seeping in and the moisture freezes on evap.
Lastly, the defrost heater(s) may not be working. Burned out, shorted, broken wire, etc.
Good luck and hope this helps.
Mar 28, 2009 | Victory Commercial Freezer VSF-3
Traulsen 46 cu. ft. Commercial Freezer G22001 Logo
91 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
