Question about LG WM-2277HW Front Load Washer
The washer (LG Model WM2032HW) timer failed about 3 weeks ago. Replace PWB number 6871EC2025D and the washer ran fine until yesterday. Now it goes down 1 minute and stops. Water continues to flow into the machine until it is turned off. Checked grounds with no improvement. Could the same PWB have failed?
  • jetport2 Sep 16, 2010
    This is a front loader. The washer locks the door and starts the cycle every time. Then it does not continue the cycle after 1 minute. I am assuming that locking will send a signal to the PWB that the door is lock and ready to go. Is there another switch at the door?
    Brigadier General:
  • 3,917 Answers
This problem is usually related to lid switch malfunction. The lid switch is mounted under the washer top casing on the right hand side. It is activated by a plastic piece on the lid through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If the lid switch is broken, the following link explains the steps necessary to replace it:
Check this link also..
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntworkatall
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Sep 15, 2010
"PE errors lg washer wm2032hw" I replaced the
Check the condition of the tube as any small crack or hole will render the pressure switch useless.
If in doubt replace the tube.
Sep 03, 2013 | LG WM-2032H Front Load Washer
No power on lg washer model wm2032hw
see the causes and fix it. Use the common sense. God bless you
If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Sep 22, 2012 | LG WM-2032H Front Load Washer
Bad vibrations/shaking with LG washing machine WM2032HW
What's the exact model of your washing machine? I'll need this to get you exact part numbers.
If you're looking for a quick and cheap fix that works. Try installing a rubber anti-vibration pad under the washer. I've had the best luck with a pad called Silent Feet. They are pretty hard to find in stores but Amazon.com carries the full line of Silent Feet anti-vibration pads. They will provide you with the best results short of replacing the full shock isolation assembly in the washer. And they cost a lot less.
Mar 03, 2009 | LG WM-2032H Front Load Washer
I got a 1997 Ford E350 7.3 run fine a week ago now its missing
hey man, check out this site. it may help.http://powerstrokenation.com/forums/showthread.php?t=19630
Dec 20, 2008 | 1997 Ford F350 Crew Cab
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Slow leak in our HE 3T Washer?
khorak, I've seen this on this model a bunch of times. The inlet valve is weeping water. You need to change it out. The top has 3 screws in the back and it will slide off toward the back. The valve sits on the left side, right up on top. Easy job, part number is 8181694. Catriver
Jun 23, 2007 | Kenmore Elite 45986 Front Load Washer
LG WM-2277HW Front Load Washer Logo
48 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
