Question about Samsung NC10-14GW Notebook
Samsung nc10 screen goes black. its power on i can see only a dark screen and a little image on the screen
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Posted on Sep 15, 2010
I have a 75" Samsung LED TV, and the top position of the screen is going dark, is that a power supply issue?
Samsung TV half the screen goes black or dark - YouTube
? 0:38
www.youtube.com/watch?v=Mmu5wq6LVgM
Jan 28, 2012 - Uploaded by DaReal2Face
Samsung TV half the screen goes black or dark. ... My samsung 40" - 14 months old does this on the top half of the screen. .. ****** 12 month ...
Sep 28, 2015 | Samsung Televison & Video
Nc10 net book black screen but power light on
is there any indication that your computer is a doing anything? After switching on, does the Samsung Logo appear for a couple of seconds, the everything goes black?
You managed to post your problem on here; if you have access to another Computer with CD burner, can you download an ISO of Damned small Linux and burn that to USB stick (using UNETBOOTIN (they are both freee... Google them) With the computer OFF insert the USB stick. switch on and AS SOON as the Samsung logo comes up TAP the F2 key, Arrow left to BOOT menu and set computer to boot from the USB stick. IF this works - it means there is a problem with your Hard Drive... Please post back how you get on.
Brian.
Oct 04, 2010 | Samsung NC10-14GW Notebook
My samsung nc10 screen goes white whilst charger plugged vin
the lcd cable that joins the screen to the motherboard is most probably faulty under AC power input. To fix it you need a new ribbon cable. Samsung will charge to sort it without warranty however the NC10 has a 12 month warranty so check your receipt date. Failing that a local computer shop is likely to be the cheapest option.
Jul 29, 2010 | Samsung NC10-14ROBL Notebook
I have a samsung nc10 notebook, when charging the
Hi
The problem you are experiencing is from either the screen of your laptop,the screen board which holds the screen in place or the screen bulb which lights up your screen.
You should get an expert to diagnose which one of the three is faulty, but at least one of the three things i have listed is faulty.
Thank you for visiting fixya
Mar 03, 2010 | Samsung NC10-14GW Notebook
Samsung syncmaster 932mw i turn it on and after about 3secs the screen goes black/off. but th power light is still on and i still have audio. for the three secs it is on i can see a check signal sign come...
same problem here, someone told me that it has something to do with the power supply. I have not been able to get the part anywhere... I thought it was totally dark but it is possible to see some images in the dark dark screen. I wish I could fix it to! :(
Oct 17, 2009 | Samsung Televison & Video
Power is getting into netbook, but screen wont light up
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 13, 2009 | Samsung NC10-14GW Notebook
Samsung NC10 will not boot up
Take it back to the store and get the manufacturers to fix it.
Jun 13, 2009 | Samsung NC10-14GW Notebook
Samsung NC10-14GW Notebook Logo
782 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
