Question about ASUS WL-500W Router (WL500W)
Intermittent WiFi with ASUS WL-500W
My wireless connection is repeatedly dropping, about every 10 minutes and does not restore automatically. Wired connections work great.
My set-up:
D-Link Air DWL 650 - network adapter
ASUS WL-500W Router
15' apart, line of sight
I checked, and should have all the latest drivers.
I've tried various security settings: WEP, WPA, open; all with the same results.
What's weird is that the Windows wireless connection manager, NEVER says that I have a connection even though I get data traffic.
When the link is up, the status is always "Not connected" but the button says "Disconnect".
When the link is down, the status is still "Not connected", but the button says "Connect".
  • 1 more comment
  • federkins May 19, 2008
    What?
    This makes no sense.
    I live in a rural wooded area. I can't even see another house or the street from my house.
    No one is stealing my signal.
    Thanks for trying.
  • bradm75 Dec 01, 2008
    The problem isn't that someone is stealing your wifi, I believe it is a problem with the ASUS router overheating. I am having the same problem and have been searching for answers myself.
    My WL-500W worked fine for about 6 months, and just recently I am losing the wifi about two or three times a day and have to unplug the router and plug it back in. My wired connection works flawlessly, just the wifi has issues.
    Brad
  • mdewig Mar 14, 2009
    It's new out of the box, I updated the firmware, wired connection works great, wifi hangs up (after 15 minutes of working great) and has slow and intermittent service... Not exactly the same problem, but close.
    The box is cool to the touch, and the router home menu has the same hangup problem. Clicking a button and waiting 10 seconds or so for a response (which typically comes fast)
    And what's this BS about having to pay for tech support from ASUS? Just thought I'd throw that in there...
I had the same problem. The problem is interferance from other devices. Solution, Change the channel from auto to a fixed one. That worked for me. No more droped connections, and a very strong signal now.
Posted on Jun 23, 2009
    Genius:
  • 1,224 Answers
Someone has tapped your wifi call your local service provider they bring out a device that searchs those hidden theives that are stealing your signal for right now i would disconnect wifi and go straight ethernet or usb till service providers tech comes out once you down your signal pull the plug for a day they should let off
and if you still want to use your internet pull only the router plug out of wall for at least 25 seconds and plug back in this resets router so connection can come back up and establish
Posted on May 17, 2008
  • Christophe Thompson
    Christophe Thompson May 19, 2008
    wifi signals can be taken from any where even if in the middle of the desert or woods
    1 pda's can wifi steal
    2 an amped signal can steal wifi signal
    3 police and fire department bands can interfere with wifi signals
    4 and or the wind is playing havic with your satelite
    all it takes is about a 100 yards to take your wifi with amped sinal
Wireless and router configuration hangups
- Kindly try to lack down the Link speed of the router and if theres any.
Mar 14, 2009 | ASUS WL-500W Router (WL500W)
ASUS WL 500 G Premium Connection dropouts.
HERE IS ANOTHER WIFI ISSUE U MY NOT UNDERSTAND BUT YOU MY BE SHARE YOUR INTERNET SERVICE WITH SOME ELSE YOU DIDNT KNOW THEY ARE STILLING YOUR MINUTES AND INFORMATION FRTOM YOUR COMPUTER
ROD
Dec 08, 2008 | ASUS WL-500g Premium Router
Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Nov 22, 2008 | ASUS WL-500W Router (WL500W)
Asus WL-500W USB printer - Can't add printer
Fixed it, remember to install the vista driver for your harddisk, then select the port of the ip to the wireless devide, then it should work, you can check in the wireless web setup that the printer is located, under System.
May 12, 2008 | ASUS WL-500W Router (WL500W)
Signal periodically disappears
do you know if reciever WL-167G is using any type of password or wireless security protocol?
Is it possible that the router is set to only allow certain mac addresses to connect?
can you log into the router to check its records and wireless settings?
Mar 29, 2008 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
ASUS WL-500W not connected to the internet
how your ADSL internet service provider, lock connection from any his machine ? Or your ISP dont provider for IP ADDRESS for DHCP or your ASUS dont set up get IP from DHCP.
Check this information.
Good Luck!
Mar 27, 2008 | ASUS WL-500W Router (WL500W)
Open Questions:
ASUS WL-500W Router (WL500W) Logo
757 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
