Question about Bose QuietComfort 3 Acoustic Noise Cancelling Consumer Headphones
Left side of the headphone bose qc3 not working
  • 50 Answers
SOURCE: Bose in-ear headphone cord cut
most head phones there two wires. those are the two that you most likly put together. if there is any metel mesh covering the wires. that has to be connected also.
Posted on Jun 20, 2008
  • 9 Answers
SOURCE: Bose QC3 makes a high pitch noise when i press it against my ear
I have had problems with my headphones as well from Bose QC3's. They will give you a new pair for $100, even if it has been longer than a year...
http://riajournal.com/ria/index.php/2009/04/25/bose-gets-5-stars-in-my-book-for-their-qc3-headphones/
Posted on Apr 26, 2009
  • 4 Answers
SOURCE: Less sound on one ear than the other
Yeah, based on all of your problems, i would safely say that you have a blown speaker. Call up Bose at 1-800-999-2673. If the headphones are under warranty (1 year) they will replace them for free. If now, they will charge you $100 for a replacement pair, which is quite a deal considering that the headphones cost $300.
Posted on May 15, 2009
Grubhead
  • 5158 Answers
SOURCE: Bose headphones only working on one side
You might want to look at my Tip on replacing plug/cable on headphones, it might solve your problem.
Posted on Apr 16, 2010
SOURCE: Bose Headphones only works on left side.
Have same problem. Play with the plug in the socket. I'll bet it you can occasionally get both working. Not a solution since it probably won't stay working. I have an old plug and it fails too. I'm afraid they did't make their plugs to the right tolerances. Used to work once. Annoying for this expensive a headphone.
Posted on Nov 23, 2010
How to replace ear cushion on bose QC 3 headphone
The ear cushions are held on the earcup with six snap fasteners, three on each side. To remove the ear cushion, simply pull it away from the earcup carefully so that you do not break the plastic snap tabs.
It should not be necessary to pry the ear cushion off with a sharp object, but if you do, be careful. There is also a thin gasket seal between the earcup and the ear cushion, take care not to damage it.
If you need to replace the ear cushions with new ones, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Apr 02, 2013 | Bose QuietComfort 3 Acoustic Noise...
My headphone, once side where the ear cup joiner with the top bit was broken. Can I get it fix? Thanks
Call Bose 1-800-999-2673 they sell replacment ear cushions for the QC3 I paid $38 for two.
Nov 28, 2011 | Bose QuietComfort 3 Acoustic Noise...
Can bose QC3 work without noisecancelling/battery?
No, the audio input must go through the active noise-canceling circuits that drive the speakers in each earcup. The noise-canceling circuits require a charged battery to operate. Unfortunately, there is no way to bypass these circuits and drive the audio input directly to the speakers.
Aug 15, 2011 | Bose QuietComfort 3 Acoustic Noise...
My QC3 make a loud whistling noise like a tea pot is boiling. I have changed my Ear Cups but thats it. I thought at first there was air entering from the small holes or that my battery was almost dead....
that happened to me when i was at the beach and had wind blowing. it stayed for several days but it seems to have gone after it was left with the battery disconnected for a few days .i would get them replaced under the Bose replacement program for $100 us
Mar 07, 2011 | Bose QuietComfort 3 Acoustic Noise...
I have a set of QC3 headphones from BOSE and the left ear has become intermittent, I know it is the jack on the headphone because I replaced the cable and same problem. I can't seem to get the ear peice...
this is what you do its the same thing that happen to my crysler aspen car the earphone wasnt like it was suppose to be it was staticing up and i know whats wrong just take it back to bose and they should replace it
Jun 28, 2010 | Audio Players & Recorders
My Bose Triport Headphones have lose cords with exposed wire.
Apr 25, 2009 | Bose QuietComfort 3 Acoustic Noise...
Slft earcup on QC3 broke off
Apr 16, 2009 | Bose QuietComfort 3 Acoustic Noise...
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
Only the left earcup works, even if i change the wire, its the same. but noise cancelling works on both.
Dec 23, 2008 | Bose QuietComfort 3 Acoustic Noise...
Intermittent Crackling noise in the right headphone
Hello Rachel, I use my QC3 for 2.5 years Mon-Fri for 3 hours a day. I have the same problem when battery is weak and/or it is cold outside. The cracking nose stops for me if battery fully charged. This is known problem andBose put it in the manual.
Vlad
Aug 28, 2008 | Bose QuietComfort 3 Acoustic Noise...
Bose QuietComfort  3 Acoustic Noise Cancelling  Consumer Headphones Logo
953 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
