Question about Vacuums
I have a necchi sewing machine model 4795 and I am having trouble trying to do zigzag stitch for applique. Can you please help me with the settings on the machine. I have tried to use manual, but I still cannot get it to stitch correctly. Thank you.
alpug
  • 1961 Answers
SOURCE: We have a Necchi model
Inspect the "feed dog", this is the spiky plate under the foot. It is the one that drags the fabric or material. Check if its already worn out and might need replacing. See also if your unit is equipped with adjustment for feed dog. Shift it up.
When you feed a fabric material, start on the edge. a small cut on the edge will make it easier to feed the material over and under the foot.
Alp
Posted on Sep 12, 2010
  • 51 Answers
SOURCE: operator manual for Kenmore 10
http://www.tradebit.com/filedetail.php/9322718-kenmore-12493-385-1249280-385-1249380-648800071
Posted on Sep 18, 2010
  • 5370 Answers
SOURCE: how can I get my
You use the setting for the zig zag stitch, but set the stitch width to it's lowest setting for straight stitch.To do a basic straight stitch, you put the top dial on the black M and the bottom one on the 0. Stitch length is the dial to the right. To do zig zag you keep the dial on the M and put the bottom dial on 3, 4, or 5. One and two appear to be used when you use a twin needle - something a beginner sewer wouldn't be using. ------- This should help.Keep updated.Thanks.Helpmech.
Posted on Mar 28, 2011
  • 5370 Answers
SOURCE: 70@gmail.comhow can I get my
You use the setting for the zig zag stitch, but set the stitch width to it's lowest setting for straight stitch.To do a basic straight stitch, you put the top dial on the black M and the bottom one on the 0. Stitch length is the dial to the right. To do zig zag you keep the dial on the M and put the bottom dial on 3, 4, or 5. One and two appear to be used when you use a twin needle - something a beginning sewer wouldn't be using. -------If you need to move needle to left side, set zig-zag width to control 5.Always make sure needle is in highest position when operating dials.The dial can be turned right or to left.Set dial at indicating point "a" according to stitch size required.For longer stitch turn to right, for shorter stitch turn dial to left.For normal sewing its between 2 and 3.--------- This should help.Keep updated.Thanks.Helpmech.
SOURCE: My Necchi supernova ultra mark
I have the same machine and I see the belt has been replaced. It's a Singer belt. You might wanna try that.
Posted on May 20, 2011
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Sewing_Machines.htm". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 | Vacuums
When in the center needle position is selected, the needle is not centered, it is left of center. When the right needle position is selected, the needle sits only slightly to the right of center. How can...
Make sure machine is set for regular zigzag stitch and not a fancy zigzag stitch, and rotate it by hand at least two full revolutions in the normal direction of rotation to make sure it is settled in to the regular zigzag stitch. Now set the stitch width to maximum width and slowly rotate it by hand, watching the needle. Does the needle strike the top of the foot at the extreme left or right? (and this is the slotted zigzag foot, right?) If not, you are good to go. If the needle does hit the top of the foot squarely, do make sure that the foot is mounted correctly and change the needle, making sure it is the correct size and that it is inserted all the way and facing the right direction. It is somewhat unlikely that the left to right position of the needle bar needs adjusting.
Sep 09, 2011 | Vacuums
Loose stitches tention loose long stitches, what should the setting be for straight stitches? for a 7318 model janome
Thread tension is more dependent on what you are sewing than machine model. Upper should almost always be tighter than lower, and the thread should pull up into the fabric being sewn.
Aug 18, 2011 | Vacuums
Where can I order a quilter attachment, seam guide attachment, embroidery attachment, for my necchi heavy duty 3205FA sewing machine?
Hi malonicus121,
Welcome to fixya!
You can order the quilter and seam guide attachments at: http://www.allynint.com/access.htm
Here is their homepage with phone numbers: http://www.allynint.com/
Since they are Necchi importers, I would guess that they could order the embroidery unit for you. Couldn't find an embroidery attachment available for this machine except on ebay. You might want to watch ebay for this.
Also, here is the website for the "SewVac Doctor": http://sewvacdoctor.com/
Not only does he give lots of answers, he does repairs. He probably would know where you could get an embroidery attachment should you have trouble finding one.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 13, 2011 | Vacuums
Hi there. i am looking for the manual for the juki HZL F300. I lost mine and cant figure out how to get a zigzag stretch stitch to work
I could only find this, but there may be others.
Details: Juki HZL-F300 Sewing Machine Instruction Manual - Photocopied Version
http://www.sewingpartsonline.com/juki-hzl-f300-manual.aspx
May 27, 2011 | Vacuums
I have a Necchi Renaissance 2 sewing machine that I can't seem to get accessories for I live in South Yorkshire, any ideas?
You could go on line and have the parts send to you. Here a web site that will help you buy the parts.
http://www.sewingstyle.com/Necchi-Sewing-Belts.html Hope that this will help you.
Jan 25, 2011 | Vacuums
My Necchi supernova ultra mark 2 (50 year old) sewing machine's belt broke (13 inch length). I'm having trouble finding one on-line. Any idea where to get one?
Oct 03, 2010 | Vacuums
I need a manual for a NECCHI Model 535FASerial nember 088549 sewing machine
You can find all the manuals for many different sewing machines and download them from the following web site.They do require some fee though.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Necchi.htm
Or you can go to this link to learn how to thread.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_534_535_threading_Diagram.htm
Good Luck and please rate 4 thumbs up for the free answer
Sep 02, 2010 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
