Related Tags:
This problem should be removed because:
Problem with Reliance & 50gal Electric Water Heater
I have a reliance 501 electric water heater. I tried to drain it but nothing came out the drain at the bottom. It is older than 15 years and I don't know if it has ever been drained. The hot
water pressure is almost non-existent. What should I do?
Solutions (1)
Best Solution
Hello At 15yrs old you got your money's worth from that tank.But a new one might not slove the pressure problem.The drain valve is clogged with sedemient.Make sure the pressure is out of the tank and poke a skinny screw driver or something to start the drain.
i need to replace the tp valve on my reliance gas
i need to replace the tp valve on my reliance gas 501 water heater...the model is 5 40 nort971...what is the shank size of the valve?
I have a Reliance 501 gas hot water heater that
I have a Reliance 501 gas hot water heater that needs a tank cleaning. Scale is showing up in faucet aerators. Is it still comon practice to...
need to empty reliance 501 hot water heater how?
how do i drain the hot reliance 501 hot water heater?
1992 Reliance electric water heater model 501 has
1992 Reliance electric water heater model 501 has two 4500 watt heating elements , there is no hot water.
Add Your Solution
I have a reliance 606 series water heater. The...
I have a reliance 606 series water heater. The pilot light won't stay lit after it goes through a heating cycle....
Model 20RS960
Leaking at the top where cold water goes in
gas water heater keeps tripping
gas water heater keeps tripping reset button
I have a brand new electric water heater that wont
I have a brand new electric water heater that wont heat the water. The elements are good and the thermostat is on. What...
what is the purpose of the extra line off the
what is the purpose of the extra line off the drain line
Related Topics
Fix-O-Meter
176
176 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Reliance Water Heater Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
