Question about Keurig B60 Coffee Maker
Water coming down all around the cannister-not through it!
    Problem Solver:
  • 5 Answers
Clean inside filter system and check for broken injector nosle
Posted on Sep 15, 2010
Can I put diluted disinfectant in the water cannister?
Unless it smells bad I wouldn't. Just always use distilled water. The unit is boiling the water so what comes out is already disinfected.
Jul 01, 2015 | Rowenta Commercial Garment Steamer - White
I am using a dirt devil wet dry vac and it is picking up water great but is spraying alot of water out of the top!
Sounds like you are not getting a good seal. Make sure it is locking tight. You may have to use some duct tape! Some have a seal around the top where the cannister is affixed. Check this, may need to get a new rubber seal.
May 22, 2014 | Dirt Devil Vacuums
Malfunction indicator light jeep 2009 wrangler
I too have had the warning on the dash indicating: "GAS CAP". It is a generic code for anything to do with the fuel cap, filler hose, or overflow, including the charcoal cannister evaporative recovery system. Sometimes it is an easy fix, to simply replace the gas cap. If people consistently twist the cap past the point where it clicks, after closing = it can wear out the cap, and prevent a good seal. However, a large majority of people have overfilled their tank too many times and the evaporative cannister is full and the overflow line is clogged or kinked. Start with the cheap solution first, gas cap.
My problem started after running the extreme obstacle course at Daytona Beach Jeep Beach 2013 at which point I pulled the cannister off the bottom and had to replace it. There are no skid plates protecting it and it would be easy for sticks etc. to get jammed up in and around that cannister while even mildly off road. Crawl under and follow the filler hose down from the passenger rear of the vehicle. The charcoal cannister is approx the size of 2 loaves of bread and sits just forward of the axle, next to the drive shaft.
Good luck.
Mar 18, 2013 | 2009 Jeep Wrangler 3.8
The red pressure relief button on my GE Smartwater whole house water filter system is leaking what do i do to stop this
I had the same problem. The valve is not seating properly. I first took a plastic bag and placed it over the unit so it didn't spray all over, then, pushed the button several times to try to flush it. I then shut the water supply off (or move lever to bypass) and removed the cannister that holds the filter. I activated the red button several times until it looked like it seated well. Keep as much water in the cannister(sump) as you can and still have the filter seated properly. Screw it back on, and open the water supply slowly to fill the rest of the way. Don't push the red button again, but instead open a faucet in your house for around 5 minutes to let air circulate out. If the red button still leaks, you may have to try a few times. If it leaks just a little it may stop after a day or so. Once you get the red button to stop leaking, don't push it again! Just always use the open faucet method to work the air out. There will still be some air bubbles for awhile, but will work out within a day
Sep 13, 2012 | General Electric GE SmartWater Household...
Evap system vapor pressure I keep getting this when the check engine light comes on does any body have any suggetion? 2000 Chevy Blazer 4.3L vortec 4x4
Start with the simple and replace the gas cap, and see if the check engine light goes out after a day or so. Post me back the DTC codes just to make sure it's not the EVAP purge valve on the intake manifold by the ignition coil.
Thank you for using fixya and good luck
Jun 03, 2010 | 2000 Chevrolet Blazer
Can I replace my gas cap?
I think you may be overfilling your gas tank. If you do this, petrol can get down the vapour lines to the charcoal cannister under the hood causing it to become saturated. This in turn would set off the cannister purge sensor and cause the check engine light ot come on. Try filling your tank only to the first click-off.
Apr 20, 2010 | 2004 Honda Accord
Code 455
code 455 means large evap leak Check 2 possible places. On the passenger side, in the engine compartment, just behind the headlight, is an EVAP cannister with a few hoses on it.
Check each hose carefully, especially on the formed bends of the hoses for cracks.
Often one of the larger hoses will split at the formed bend in the hose, right where it connects to the cannister.
If those hose check out ok, then under the cab on the passenger side, on the frame, you will find another cannister. On the top of the cannister, a bit out of view, is a few other hoses. Often, those hose will split or come loose from the cannister, right at the connections.
With the EVAP large leak code, it is likely that one of the hoses has split or come loose from the connections.
Mar 28, 2010 | 2001 Dodge Dakota
How to put in ac gas
Easiest way is to purchase a kit from your local parts store. A kit usually comes with one or two 150 ml cans of freon and a hose kit with gauge (plus instructions). The cost should be around $40. The intake valve on the A/C under the hood is a universal valve that the hose connects to, and the other end connects to the cannister of freon. Be careful not to overfill - monitor the pressure gauge - as you can trip the shut off switch and shut down the AC altogether.
Jun 07, 2009 | 2002 Nissan Maxima
Brush does not spin
definetley the belt if its the cannister vac like mine there is 2 screws on the bottom towards the back wheels take em out. on the side u have to pry open gently on the back side as well the top should come off and you should see a w plastic shroud around the roller there is a clip latch take the shroud off theres the belt
if not cannister vac on underneath the cover should have 4 or 5 little screws take em out under cover is the belt
hope that helps. gl
Dec 29, 2007 | Vacuums
Keurig B60 Coffee Maker Logo
48 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
