Question about RCA HD52W66 Projection Television
Power light keeps flashing on and off WELL FIRST OFF I HAVE AN RCA TV..MODEL # (HD52W67) ITS A 52 INCH INTEGRATED HD WIDE SCREEN PTV. WHEN EVER I PLUG IT IN AND PRESS THE POWER BUTTON, IT JUST BLINKS. I DONT KNOW WHATS WRONG WITH IT BUT IT MAKES THE SOUND LIKE IT WANTS TO POWER UP BUT THEN IT JUST KEEPS REAPEATING THAT SOUND....IT SUXX I WANNA WATCH T.V.!! SO COULD SOME 1 TELL ME WHATS WRONG WITH IT AND WHAT I NEED 2 FIX IT??????? PLEASE AND THANK YOU!!! EMAIL-YUNG_SAV_BITCH@YAHOO.COM
  • Anonymous Apr 08, 2009
    WELL FIRST OFF I HAVE AN RCA TV..MODEL # (HD52W66) ITS A 42 INCH INTEGRATED HD WIDE SCREEN PTV. WHEN EVER I PLUG IT IN AND PRESS THE POWER BUTTON, IT JUST BLINKS. I DONT KNOW WHATS WRONG WITH IT BUT IT MAKES THE SOUND LIKE IT WANTS TO POWER UP BUT THEN IT JUST KEEPS REAPEATING THAT SOUND....
  • RCA Master
  • 5,138 Answers
3 capacitors cp150 220uf 16v cp114 cp120 -they are 220uf 35v. replace thes 3 caps and this will fix your TV.
Posted on Dec 26, 2008
Have sound but no picture.backlight LEDs flash once on/off 1st on.can see picture on screen (any channel) using flash light...already tried new LED converter...all working then screen went black.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 06, 2016 | Hitachi Televison & Video
Tv turns on and screen flickers on for a second and then turns off, whats the issue?
Sounds like Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS].In such cases, the power supply board might need replacement.To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself.If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board.If this is the case, you have to replace the main board.
Jul 28, 2016 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
Sony Projection Wega TV
It was better to replace the light engine as a unit to such an old PTV.
Electro help
Jul 27, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
My RCA 42" HD flat
sounds like it needs new caps on the power supply board..............easy fix if you can use a soldering iron........
cheers
Apr 07, 2011 | RCA L42WD22 42 in. LCD Television
Model 52" hd RCA tv Will not go on.hit power button green light keeps flashing.will not stop
These units are famous for bad capacitors in the power supply. When the capacitors go it causes voltages to fluctuate out of range. You have to remove the deflection PCB to repair this. Also look for loose connections at the high voltage transformer. This can be a dangerous circuit to work on. Have a repair shop check it out for you. Thanks
Oct 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca flashing the menu screen
a professional. Electronics go threw a self diagnostic to check for problems. it sounds like it's found one.
Jun 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Check the buttons on the front keyboard panel. Try cleaning them if that's no help replace the panel or the buttons.
May 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony wide screen projection tv 46 inch
you might check the power relay and the main power supply or have a tech do it for you.
Jul 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA HD52W66 Projection Television Logo
241 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
