Question about Microwave Ovens
How do I take apart my dyson dc04 to fit a new wire
Ensure the device is disconnected from any power source before taking any of it apart. The power button is held in by a little catch which can be accessed by a small hole between the button and the vacuum body. Even if you can find something that fits down the hole it will be difficult to clear the latch. Once the button is out there is a torx screw holding the actual switch and wires down. The wires all have spade fittings inside plastic sheathes. Ensure the device is disconnected from any power source before taking any of it apart.
Posted on Nov 01, 2012
I have a Kenmore microwave mounted above my stove. The light that lights my stove is blown and I can't find the right replacement bulb. It has two little prongs that should fit into the unders
Are these little spot lights? About the size of 1/2 dollar round and maybe 1.5 -2 inches long? 2 prongs about 1/2 inch apart? Take one of those lights and show it to a local hardware dealer like "Lowes". There are may types and some are 12V some are 110V. Thats why I suggest showing to the local hardware guy.
Jan 12, 2015 | Microwave Ovens
DA 399 mEILE RANGE HOOD CANT GET OLD GLOBE OUT TO CHANGE HALOGEN 50 WATT
Remove the grease filters. This will expose the two screws that hold the lamps in. Turn the screws anti clockwise until the lamps drop a little. Twist the lamps gently anticlockwise to release them from the fittings. My instruction manual says reverse the procedure to insert new lamps. Haha. Good luck and be careful.
I had a lot of trouble getting the lamps back in. So much so that I have somehow damaged the fittings or wiring and now have to have a repairman out.... looking at $150 plus just because a light blew!
Feb 01, 2011 | Microwave Ovens
Need instructions for replacing light bulb in Sharp Microwave Oven Model R430EK
When you have the new lamp to hand, so you know what you are looking for, remove from the mains supply and remove the case. The lamp is generaly near the vent or transparent poit in the cavity, that used to let the light shine through.
Remove the old lamp and fit the new one, taking care not to leave any wire ends free.
Jan 05, 2011 | Sharp Microwave Ovens
A kettle of soup boiled over on my new Kenimore Elite Electric Range. Some of the liquid that fell down the front went into the vents at the top of the door and dripped down onto the inside of the glass...
This question was asked almost 2 years ago, but thought I'd respond anyway. On the bottom of your oven door there are slots. Pull out the drawer beneath the oven door so you can work under it. Find something that will fit through the slots, a yard stick worked for me, or maybe a wire coathanger. Attach a paper towel or cloth securely to it and put it though the slots to reach the soiled area. It will take some manuvering. I would not recommend taking the door apart. When I did some research on this some time ago, I read that it can be difficult or impossible to get it back together again.
Oct 11, 2010 | Microwave Ovens
The microwave function stopped functioning. Anew
ck the door inter locks . . but if its just been apart for a mag . I would look first at wire connections or pinched wire ..ect . these are common after major service ..
Dec 31, 2009 | Microwave Ovens
I have an error code on my new LG LDF 6920st dishwasher. It runs for about 10 minutes and then dings and flasher LE
I would suggest calling the seller or distributor and having this unit replaced.
This error is not part of the consumer repair area and should only be done in A workshop here are two preevious ownrs experiences
1)
LE ERROR CODE
YOUR MOTOR RING CAME APRAT
THE UNIT EMPTIES AND REFILLS AND STOPS AT WHEN IT TRYS TO WASH I had to take the unit apart from the inside to comferm the motor is stuck. remove the racks the spinner in the bottom, the screen assy (1 foot in dia.) the wheel of pump with left hand threads, make sure it is unplugged, try to spin the garbage disspser blade. if it has trouble spinning then, pull out dish washer unit and flip over and remove the cover on botom and the motor and ground wire. good luck. i have had to replace mine twice now!
2)
I had the same problem and was told it was the motor. Well, it wasn't the motor. Take the front panel off & look at the wiring harness. There was a wire broken, not to mention the insulation was in the wrong place. It should be between the inside wall (dishwasher tub) and the wiring harness this way the wires wont get hot and break. Simple fix but, I would have never thought to take the door apart.
This unit is under warranty and should be attended to by the technicla support. LG are not good quality at any time, now made in Korea as cheaply as possible.
Please rate my help++++Thanks for using FIXYA
Nov 16, 2009 | Microwave Ovens
Where can I take my Emerson Microwave to be repaired? Microwave begin to spark where light bulb is and smoke, leaving a burnt smell in the air.
Check the wires for the door switches make sure they are not touching. If they are pull them apart and put new ends on or just some electrical tape.
Mar 21, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
New GE Magnetron. Where does this new HV diode go?
Fixed it. There was a back capacitor fuse (I believe that's what it's called) on the old magnetron. I removed it and put it on the new magnetron. The HV diode is on the big silver capacitor and very easy to replace. I just didn't see it. It was definitely the magnetron and I hope that this new one comes with a warranty for 5 more years.
Nov 29, 2008 | GE JVM1631 Microwave Oven
Sharp Carousel
What is your model number?
Aug 06, 2008 | Microwave Ovens
Shorting Out
The control panel drops down (keep attached at the bottom).
Fold or cut the film to fit over the frame, and use regular scotch tape to attach it. Don't cover the little holes where the panel needs to be hooked back into. Cover as much as you can down to the group of wires on the bottom.
Hope this makes sense--not a very technical answer.
My microwave is working just fine.
Jan 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
