Question about HP Deskjet 5940 Photo InkJet Printer
My HP 5940 Deskjet Printer has 3 lights flashing rapidly and simultaneously. The lights are the power button, the right hand ink button and the paper out arrow. I tried repeatedly to turn off the printer, but it comes right back on and begins the whole process over again. If I hold down the power button for some time, the lights repeatedly go through the normal sequnce they did when I would first turn on the printer before this issue. As soon as I release the power button, it goes back to the rapid blinking of the 3 lights. The only way I can turn it off is by pulling the power plug. I removed the ink cartidges and reinstalled them, have installed a new right hand (Black) ink cartidge, have tried a different USB cable and port on my computer, have disonnected the power cord to the printer over night and have removed the driver and reinstalled it. Same result in each case. (The color cartridge is fairly new and nearly full of ink.) I also tried wiggling the cartidges a little to see if they were hung up, but they appear to be free. Any suggestions to resolve this issue would be appreciated. Thanks very much.
  • HP Master
  • 16,974 Answers
Carriage is jammed, unplug the power, move it by hand all the way to the left. check for debris, plug it back in and power on.
Posted on Mar 04, 2017
SOURCE: troubleshooting on hp printer/scanner/copier
This looks like either there is an paper jam or carriage jam on the unit,
Check the rare access door weather there is a paper jam.
Remove the cartridges and try moving the carriage( the cartridge hold) left to right and right to left and check if its moving freely.
After these try disconnecting the power cable without turning off the unit and hold the On button for 15 secs and then plug in the power cable while your hold the on button.
This should probably fix the issue.
Please do let me know if there is still an issue.
Posted on Feb 19, 2008
SOURCE: printer deskjet 3650
saks
Posted on Jul 10, 2008
  • 54 Answers
SOURCE: MP530 Print Cartidge Problems
Hi shortiered,
Sounds like your orginal driver installation has become corrupted. Try this: completely remove unit and its software from your computer, not forgetting to unplug all cables. Go to the folling url(copy and paste in the address bar) for the latest software for your unit. It's easiet if you create a new folder on your desktop and name it mp530 drivers, save down load here. Install software first, reboot and plug your cables in, windows will reconize new hardware and install it for you or it may ask if you have installation disk or installation file, click yes and direct download to the folder you created for your new drivers. I hope this helped a little, if not, hit me back, we have other options.
Thanks for using FixYa.com
Sincerly, cyyyd7
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=13371#DownloadDetailAct
Posted on Oct 09, 2008
crayzeetrayn
  • 837 Answers
SOURCE: It's giving me (DCP 115C) no cartidge, insert black cartidge
Put a new cartridge in. Yes the printer needs that cartridge
Posted on Dec 06, 2008
Roop1980
  • 228 Answers
SOURCE: still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Posted on May 26, 2009
HP Deskjet 5940 won't recognise new black ink cartridge
Check to make sure that the contacts on the printhead carriage is clean.. Remove both cartridges. Unplug printer.Wait at least 3 minutes. Plug printer back in. Printer will turn on. Reinstall cartridges.
Dec 30, 2013 | HP Deskjet 5940 Photo InkJet Printer
All lights rapidly flashing--ink cartridges wont
i had this problem and found that holding down the power button for 5 seconds and then letting it power oww, solved the problem for me. if that fails, unplug the power cord and allow printer to sit for a few minutes. My 6940 gives me a bit too much trouble at times!!!
Dec 26, 2009 | HP Deskjet 6940 InkJet Printer
HP deskjet 5940 printer - lights flashing rapidly and not responding.
>flashing lights or a cobination of lights blinking on your printer will tell you exactly what the problem is, go to this link and see the steps on resoling the blinking lights on your printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00394958&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Oct 03, 2009 | HP Deskjet 5940 Photo InkJet Printer
Printer says out of ink, won't print
Greetings,
Try this In service mode.
Put Stop/reset 4 times orange => reset waste ink.
Put stop/reset 8 times orange => set level ink.
This isn't set level but it disable ink check. The LED warning still blink but no error code appear anymore.
Regards,
TechSup1
Apr 30, 2009 | HP Deskjet 5940 Photo InkJet Printer
Can't find ink levels for my HP Deskjet 5940
The installation disk for your printer has a setup wizard that monitors your ink levels in your printer. Go through the installation again as it will not hurt anything and you should find it on one of your pop up screens that it leads you to.
Jan 14, 2009 | HP Deskjet 5940 Photo InkJet Printer
When printer is plugged in the power light blinks,
hi some printer lights blink due to an fault (hardware or software)
Dec 04, 2008 | HP Deskjet 5940 Photo InkJet Printer
Nor printing
Go to http://h10032.www1.hp.com/ctg/Manual/c00453087.pdf which is the HP online manual for this printer. Open it and go to page 92. Follow the recommended troubleshooting steps carefully.
Note: It is likely that the cartridge you installed is "dry". Or (and this one is no fun) the cartridge you purchased is not compatible with the 5940. Does the left-side panel of the wrapper carton have a listing of "5940" under the paragraph HP Deskjet ?
Also, if you purchased a store-refilled or store-recycled cartridge, it may not work. I had this happen once with a refill. Sorry, but you'll have to dispose of the recycled cartridge and purchase the reall HP deal.
Oct 15, 2008 | HP Deskjet 5940 Photo InkJet Printer
HP Deskjet 5940 Photo InkJet Printer Logo
2,862 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
