Question about Sony Playstation 3 (PS3) Console
At start up the green light turns yellow red light flashes and system powers down. What should I do?
  • 358 Answers
Hi,In order to fix PS3 green light flashing problem you're going to have to do some troubleshooting on your machine. The usual steps of unplugging everything and doing a hard reset apply. These are universal and advisable for any error on any console. If this doesn't work then you're going to have to go a bit deeper into your PlayStation.
Typically you get this error when something is not operating correctly inside the unit. This is different from a display or hardware errors, these still allow the console to be turned on. In the event you need to fix PS3 green light flashing problem chances are something is not working with your power supply.
If the PlayStation 3 detects a problem in the power supply or any other components that might cause severe damage it will not boot. If you want to fix PS3 green flashing light error you need to track down the faulty component and replace it. Do note that this is a safety feature designed to keep the console from overloading and requires some dis-assembly to fix. If you are uncomfortable disassembling your unit to fix PS3 green light flashing problem then you should send it in to get it fixed.
Have a nice day.
Posted on Sep 15, 2010
Testimonial: "Thank you very much for you help."
My ps3 will not power up
here is step by step trouble shooting
1) attempt to turn on the ps3
+you will see one of 4 things a green yellow red light
+flashing red light
+green light
+no lights
2) if you see a green yellow red light call sony your system will need service
3) if you see a red flashing light also call sony needs service
4) if the light is green turn off the system and one the light is back to red press and hold the power button for a series of 2 beeps (do not forget the one when you first push the button down) then let go (it might be a video issue)
5) if you still see no video and a green light check the cable you are using and try again on a different tv
6) if you see no power light call sony it needs service
these are genuine trouble shooting steps from sony technical support if you do have to call them be prepared to follow the same steps that lead up to service. thank you
Oct 30, 2011 | Sony Playstation 3 (PS3) Console
Turn on system, it flashes green than a yellow flashes then to red flashes. i have unplugged everthing even shut down power towhole house...and nothing.
Yes this is the red/yellow light and you will need to get it fixed, it is not a power surge unfortunately!
It is the motherboard taking too much heat!
You can fix it at home with a top guide or send it in.
May 31, 2010 | Sony PlayStation® 3 (80GB) Console
Turned off and won't start. the light turns green then yellow then flash's red
The temperature inside the system is very high. Check whether the system is being used in a hot location OR the vents are not blocked. Touch the power button on the system front to stop flashing and then turn off the system until it cools down After it has cooled down, turn on the system again.
Mar 11, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
My Ps3 isnt starting, light turns green then changes to yellow
this is the ps3 equivilent of the xbox360s red ring of death error, sorry to tell you but that means a serious system error has killed your ps3 its unfixable and you will have to send it off for a replacement
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Sony Playstation 3 (PS3) Console Logo
150 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
