Question about LG DLE2532W Electric Dryer
Runing fine but does not dry, no hot air - LG DLE2532W Electric Dryer
  • LG Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 15, 2010
Hi.04 mitsubishi galant have problem my sevice engine light remains on.i have code p0132 and car when it get hot runing rough. thank you
your o2 sensor bank 1 is bad . you may want to replace it. It will probably solve your problem but make sure your maintainance is up to date fuel filters air filter plugs and wires. If this was helpful please leave good feed back
Feb 18, 2015 | 2004 Mitsubishi Galant
The car will be runing just fine then it
could be that the idle air control may have to be set,
Jul 01, 2010 | 1992 Chevrolet Camaro
Kenmore 62064 elec. drying is runing (all buttons
Hi Sam,
Make sure that you have checked the circuit breaker, to find out wither or not the breaker was tripped or not, before you take it apart. but there is a good chance that you are right on the money......
Dec 12, 2009 | Kenmore 62062 Electric Dryer
Car is runing hot after i replace the thermostat
You have either put the new thermostat in the wrong way around ,so it isent opening up so take it out and turn it up the correct way(spring looking part to the bottom) engine side,
OR it needs air bleeding from system like turning the heater to hot before filling with antifreeze to get out the air from the heater when you start and run.. Ron
Nov 17, 2009 | 1995 Pontiac Grand Am
It takes 3hours to dry a load of clothes even thought it is getting hot.
before you move the dryer,look behind the dryer and see if the vent hose is pinched off.if it is not pinched off than try runing the dryer with out the vent hose hooked up.if the dryer drys well than you have a blockage somewere between were hooks up to your dryer and outside vent.
Nov 09, 2009 | Whirlpool LER4634J Electric Dryer
Dries very slow lint is clean have to run and run to dry
make sure the outlet tubes are also clean, also rinse off the lint screen with hot water, softener will clog it and not allow propper air flow, the water wil bead up on the screen if this is true, just keep rinsing till water flows freely
When i turn the hot water tap on to get hot water the red pilot button keeps going on off and clicking , after some time runing hot it goes cold and the other warning light starts flashing. its a...
Air conditioners do not provide hot water, and gas air conditioners are very rare. I think you would have better results if you post this in a different category.
Jul 27, 2008 | Heating & Cooling
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Urotech EWC177 Combo
Same problem here and mines brand new. Seems the dryer consists of only a heating element. There's no circulation of dry air. You may as well hang your clothes inside a steam room.
Mar 10, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Blower won't stop runing.
First I would make sure that at the thermostat your fan is not in the on position rather than auto. Your other options are that your blower relay may be "stuck" or possibly the installer wired it improperly making it hot all the time.
Oct 25, 2007 | Heating & Cooling
LG DLE2532W Electric Dryer Logo
49 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
