The house power filckered 3-4 times and stayed off 24 hours. When power resumed, fridge has power but won't cool.
Hello AnnArborMom, thank you for your inquiry!
I would recommend you adjusting the temperature to a lower setting to see if that would start your compressor to cool. If that is not successful I would contact a professional to come and properly diagnose your appliance. It could be that the power outage shorted the main control board or relay. I hope this is helpful. -Matt
The manual reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit
completely. Then keep both the doors open. Wait for 24 hours. All the ice
collected on the coils and in the freezer section will get melted.
Clean the water from the sections. Then Connect the power cord of the unit to
main power outlet after 24 hours/.Then set the temperature to normal in both
fridge and freezer section. It will take approx 4 to 6 hours for your refrigerator to regain its regular cooling/ freezing .So after 4 to 6 hours check , Is the refrigerator cooling properly or is it taking time or temp is dropping once you open close door. If this problems are not noticed, then reset procedure has helped.------- But if same problem is noticed after reset procedure is followed, then you can get the compressor checked.
This should help.
Thanks.Helpmech.
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
you can get the required
parts from online sites like:---
from searspartsdirect online site.---------This will help.Thanks.Helpmech.
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts check if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
I replaced the start device and the fridge is working fine. The inside of the old start device had disintegrated. Thanks for your help.
