Question about Refrigerators
My frigidaire model GHSC39EGOB0 does not cool at all. I noticed the fan got stuck with the wires. I fixed it but still the same problem.
  • osvaldo perez Sep 15, 2010
    The compressor is working but the the frizzier does not coll at all
    The compressor is working but the frizzier does not cool at all
  • 17,130 Answers
Was the lines connected with the correct colours. Did you check on the wire continuity if in case it was shreaded within. Does the fan work after the lines were connected?
If there was no frosting after the compressor was switched did the frost/cooling appear within. If not you must check if the compressor is running low RPM chek the capacitor to the motor. Check onthe gas pressure.if there is no cooling at all.
Posted on Sep 16, 2010
    Problem Solver:
Ok, thanks
Posted on Sep 15, 2010
  • Refrigerators Master
  • 43,501 Answers
After fixing the fan, you may have to unplug the unit and then let it cool down before the compressor will start again...there is a thermal overload on the compressor that will need to reset....
It is possible though that the compressor got too hot a is ruined or that the start relay and capacitor are fried because of the fan stoppage. Let the unit cool down and them if the compressor will not start then check out these tips. They will give you more info on the compressor situation...
RefrigeratorCondenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
  • D. Floyd Kolb
    D. Floyd Kolb Sep 15, 2010
    Then the two things are not necessarily related... if the compressor is running and you are not cooling then you must also have a leak in the refrigerant system and you will need to get a pro to place gauges on the system and check it...if you have a leak it will need to be found, fixed, and the system recharged...
    heatman101
    ok, thanks
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Frigidaire will not
The problem lies in the control board. Either a fan relay is stuck in the "on" position or the circuit controlling the relay is bad. A decent electronic tech or a new control board should fix the problem. Considering the value of the unit, it would be worth doing a troubleshoot and component-level repair if possible. If not, you can contact a local appliance parts house to order a new control board.
Mar 30, 2014 | Frigidaire Fra18emu2 18500 BTU Cool/16000...
Frigidaire dryer blower fan keeps getting stuck.
Since you didn't leave a model number, I will have to give you a generic answer, instead of one with a part number of the most likely replacement part. Normlly the problem you discribe is a result of the blower motor bearing wearing out and letting the fan blades rub against the housing. And since the bearing is internal to the motor, you have to replace the entire motor.
Dec 30, 2011 | Frigidaire Dryers
I moved my refrigerator to vacum (Frigidaire model PLHT217TAK 2002) and since then the warm air stopped coming out from the front bottom vent. It also stopped making noise, it seems to want to start but...
the condenser fan motor is what blows the air around down there,pull out the machine remove the back bottom panel and you'll see the fan,check it to see if something is stuck in the fan blade keeping it from spinning,do this right away,if the fan isn't blowing you can cook your compressor,if something is wrong with the fan motor you can leave the bottom panel off and stick a regular fan back there to keep the compressor cool until you fix the fan motor.hope this helps
Jun 23, 2011 | Frigidaire Refrigerators
Hi, I have a GE GSS25JERF model refrigertor. I noticed it is not cooling and fan is stuck and not working in freezer section. Dispenser light is blinking. highly appreciate for any guidance
OK, Now would be a good time to see why the evaporator fan is stuck or not powered. Question is will you feel comfortable testing these items. I will give you a link to a Test Sheet and wiring diagram here=> GE GSS25JERF and I will be here to assist you. Thanks, Sea Breeze
Aug 24, 2010 | GE GSS25JF Side by Side Refrigerator
My frigidaire refrigerator does not cool? what should i buy for it
Good day.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condensor
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
Thank you for using FixYa
Jan 17, 2010 | Refrigerators
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Frigidaire PLHS267ZCB4 side by side, no ice or water, not cooling
I have the same problem. The repair people replaced the control board, but it did not fix the problem.
Mar 17, 2009 | Frigidaire Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
