My Acer Extensa 4620 won't turn on says "critical battery" but I have the power source plugged in. It just shuts itself off. What can I do? THe charger seems to be working.
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 15, 2010
Acer extensa 4620 bluetooth peripherals drivers for windows 7 ultimate x64
You can only do it with a bluetooth dongle, it won't work otherwise.
Jul 06, 2012 | Acer Extensa 4620 Notebook
Acer 4620 is dead
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 25, 2011 | Acer Extensa 4620 Notebook
Hi I can't open my acer 4620 . press on the power but the light only on for a few seconds and then went off again
hi sounds to me you might need a new battery ,or try remove the battery and plug the charger in then it will work without the battery ,check to see if theres power comin out of the power supply with a multimetre should read about 18-19volts hope this helps you goodluck
Mar 25, 2011 | Acer Extensa 4620 Notebook
New acer extensa battery price
try this link
http://www.batteryuniverse.com/Laptops/Acer/Extensa-4620/CONIS71_Acer_Extensa_4620_Laptop_Battery
Feb 24, 2010 | Acer Extensa 4620 Notebook
Notebook shuts down by it self
Your heat sink and cooling fan are dirty - you need a can of compressed air and some small screw drivers - or you could just take it in and get it cleaned professionally.
May 03, 2009 | Acer Extensa 4620 Notebook
My Acer Extensa 5620 laptop will not power up
if you move the cord around in the back of the laptop will it power
sometimes the internal piece inside the laptop become lose from constant plugging and unplugging
Jan 13, 2009 | Acer Extensa 4620 Notebook
Computers & Internet Logo
David Payne
David Payne
