Question about Apple iPod nano
Ipod locked up
My ipod screen is locked up. I've tried pushing the menu button to reset
it but it doesn't seem to work. Any ideas ?
  • Apple Master
  • 13,433 Answers
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If that solves it remember to rate as fixya, if you need more assistance let me know.
Posted on May 16, 2008
  • Ekse Jun 01, 2008
    This thread has gone 7 days or more without a response. Please close the thread with a “FixYa” or “Helpful” rating.
    If the issue is not resolved, please post back with latest developments, what steps you took, etc. and I will assist you further as best I can.
    Thank you.
My ipod touch 4th generations says ipod disabled connect to itunes, but screen is locked
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Jan 19, 2013 | Apple iPod touch 4th Generation MP3 Player
My kodak dcs pro slrc menu doesn't work and the camera seems locked up. Any idea?
Hello Dana, Remove battery and fully charge or replace with new, then try to start camera again. If camera does not reset itself it will need serviced/repaired.
Dec 07, 2012 | Kodak Cameras
My 8GB IPod touch won't turn on at all. I've tried the whole power and home button pushing stuff but still nothing. Can anyone help me?
Hi Amanda,
This may take a little trial and error, but it has worked for me in the past. Press down the refresh button on the top edge of you IPOD and the back/Menu button on the front of your IPOD at the same time and hold them compressed until the Apple logo appears. It may take up to a minute or more before it resets. You may also have to do it more than once. Oh and make sure it has been charged. Hope this helps! Please repost another question with more info if you need help.
Dec 01, 2012 | Apple iPod touch
Ipod instructions to unlock
Try to reboot it by pressing the center button and menu at the same time for about 6 seconds. If that doesn't work, try resetting it to factory defaults using iTunes.
Dec 22, 2011 | Apple iPod mini 2nd generation MP3 Player
My iPod turns on but the buttons dont work! They were working just fine then they stopped! How do i fix it?
Try this! http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_nano.htm Difficulty: Easy Time Required: Less than 1 Minute Here's How:
  1. NOTE: First make sure that your iPod’s hold button isn’t on. This is the little switch at the top left corner of the iPod video that you can move to “lock” the iPod’s buttons. If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod’s screen. If you see either of these, move the switch back and see if this fixes the problem.
    If the hold switch wasn’t the problem do the following:
  2. Move the hold switch to the on position and then move it back to off.
  3. Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod nano. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
  4. If this doesn’t work at first, you should repeat the steps.
  5. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
  6. If this doesn’t work, you may have a bigger problem, and ought to get more help.
Aug 03, 2010 | Apple iPod nano
Is their a master reset for the Ipod nano screen lock combination? have no idea what the combination is. please help
You can reset the ipod by holding down the centre button and the menu button for apprx 5 seconds, the ipod will turn off and come back on again having been reset, no music etc will be deleted.
Dec 04, 2009 | Apple iPod nano
My ipod nano 4G is locked.
try plugging it into itunes and reformatting it to its original state, if that doesn't work turn it off by pressing the menu and play button, then directly aftewr push the menu and revers button, i think you can reset it from there.
Jul 24, 2009 | Apple iPod nano
Ipod restore problem
try updating the ipod to the latest firmware and then ur ipod should be fine if not then try reseting it
how to reset,
1) lock ipod by pushing the top button on the ipod for 5 sec.
2) after u unlock the ipod push the middle and menu button and it will reset.
Mar 23, 2009 | Apple iPod classic MP3 Player
Frozen screen
First, make sure the lock slider is in the proper position.  I know, obvious, but you'd be surprised how often this happens.
Next, slide the lock slider to locked and then back.  Then press and hold the Menu and Select (center) button for 6-8 seconds.  Try a couple times if it doesn't work the first time.  The ipod should reset and work.
If that didn't work, you can reset your ipod.  But first, try connecting the ipod to your computer and see if it goes into sync mode. If so, wait for iTunes to load and then eject your ipod in iTunes and see if it works again.
To reset your ipod, slide the lock slider to locked and then back.  Next hold the Play/Pause Button and the Menu button for 6-8 seconds.  You may have to try this a couple times.  The ipod should reset.
The last thing to do is to let your ipod discharge completely by leaving it at the frozen screen.  Once your ipod is out of battery, reconnect it to you computer or a power adapter and let it charge.  Then try to access it again or repeat the steps above.
Nick
Jan 22, 2009 | Apple iPod nano
Black Screen
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
Mar 25, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
173 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
