Question about Toshiba Satellite P205-S7806 Laptop
Over the last few months I have noticed my computer getting slower and slower. Things like it takes 10 minutes for it to fully start up and from time to time it will push everything into the background (Don't know how else to describe this. It whites out all my applications) and I can hear it loading something for sometimes 2-3 minutes, it's starting to take several seconds just to switch back and forth between windowed applications. Any help on this would be great. I run a Toshiba P205-S7806 that is 2 1/2 years old. I know I need to give you more but don't know exactly what so just let me know how I can clarify.
  • 8 Answers
SOURCE: Portege 7200CTe battery life short
I don't know for sure if this is your problem, but I do know that laptop batteries normally have a certain number of full charges before they tend to stop working well. I have seen your problem happen to several different laptops. One way to check this would be buy a new battery for it. If it works fine with that, the problem was the battery and you now have a replacement. If it isn't, however, you have spent the money on the battery and it hasn't done anything. So, that is up to you. That's the only thing I know of, tho. Or if you know someone else with the same laptop, try putting their battery in. Like I said, I don't know for sure if this is the issue, but I have seen it happen to several laptops and a new battery usually fixed it or at least figured out what the problem was. I don't know any way to figure out if that's your problem without buying the battery first, but there might be a way.
Posted on Jan 06, 2008
clickman
  • 93 Answers
SOURCE: All for Toshiba Satellite P205-S6287 notebook
I am thinking that he just provided a set of drivers for this Laptop...
He simply put it there and said nothing...
Posted on Jul 22, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Help Me
Here's a link to the drivers list for your machine at Toshiba's support site.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1909329&rpn=PSPB3U&ct=DL&BV_SessionID=@@@@0537614255.1216835046@@@@&BV_EngineID=cccfadeejkmemelcgfkceghdgngdgnn.0
Posted on Jul 23, 2008
cpenzes
  • 1102 Answers
SOURCE: Toshiba Satellite M45-S265 Periodic Freezing, resumes, clock stop
do a virus scan
in add/remove uninstall any programs you no longer use
then do a disk defrag
then a scan disk
have you made any changes to system
please let me know if this has helped
don't forget to rate
Posted on Feb 14, 2009
yourpc
  • 190 Answers
SOURCE: Toshiba M45-S165 startup issues
This is normally a motherboard issue. I had one with the same symptoms and I had to replace the motherboard. Worked great after the board was replaced. I had to replace the board because unlike your issue mine stopped working all together. It did take a while before it quit though. Just a note: I have had to replace several of these motherboards for customers as well. If your LCD is broken, you may be better off to save your data and put it in a new laptop that would include a warranty unless your super fond of the machine or you have access to inexpensive parts.
Hope this helps...
Posted on Feb 15, 2009
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
How much warm up time does a dodge sprinter 2500 diesiel require in the winter time?
At idle it can take hours to fully warm up
If your concerned about driving it right away after starting, not a big issue.....start, let it warm a min or two then drive.
Diesels warm slower than gas engines, and they take longer to get warm enough to give you heat untill fully warmed up.
Normally you should see good temp and good heat after driving about 15 minutes after the first cold start of the day.
Feb 02, 2010 | Dodge Sprinter
Fully charged battery in and it only lasts few minutes
you have to buy lithium battery's or lithium rechargable's. that camera should of came with lithium battery's did you get it used? and it should take usb.
Jan 02, 2010 | Sharp Viewcam VL-AH151U Camcorder
Graphics card or motherboard problems...
You've run the antivirus. Next, try to run malware & spyware programs. THen, run a good registry cleaner. This will aim the right things with the right things. If you made ANY changes to hardware, software, programs or data, there will be changes in your registry.
Jul 15, 2009 | Gateway FX7026 PC Desktop
1996 Oldsmobile Achieva: Security light flashes upon startup
Here is what you do, but only when the SECURITY light flashes - if it is always ON or OFF it's no use.
Turn the key in the ignition to ON.
Wait for exactly 10 minutes ( SECURITY light will flash for 10 minutes and then stay on SOLID)
Turn the key to OFF
Wait 5 seconds.
Wait for exactly 10 minutes.
Turn the key to OFF
Wait 5 seconds.
Turn the ignition OFF.
Start the car normally.
It has relearnt the keycode and you're good to go.
NOTICE - it takes 30 minutes to relearn, that's THREE cycles of ON - 10 minutes - OFF.
Good luck.
Jul 11, 2009 | 1996 Oldsmobile Achieva
Battery problem and TIme and Date setting
it is worth repairing... olympusamerica.com/repair
Sep 09, 2008 | Olympus FE-210 Digital Camera
IBM 21" frequent tick sound!
too much refresh rate! set it to 60 hz only! you're over-stressing major components on your monitor!
Dec 02, 2007 | IBM P 202 21" CRT Monitor
Svchost.exe using 100% CPU at startup
this is an all too common problem with windows services host, but you will have to refer to this site as there are a few things you can try http://ask-leo.com/svchost_and_svchostexe_crashs_cpu_maximization_viruses_exploits_and_more.html
May 29, 2007 | Toshiba Satellite 2400-S251 Notebook
Toshiba Satellite P205-S7806 Laptop Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
