Question about Panasonic KX-T7630 Corded Phone
Have 2 lines on my panasonic phone, the first line has no dial tone
  • Panasonic Master
  • 2,460 Answers
Do you plan on doing anything to help yourself? In a room somewhere, there's a Black and Blue cabinet wiht jacks on it. One of those jacks is the one that contains dial tone for line 1. You also have an interface somewhere that has line 1 and it has a modular jack to plug into (usually). You have to take a REGULAR phone, not the Panasonic digital phone, and plug into the line to determine if it's inside or outside trouble. It will probably be outside, then you report it to whoever supplies your phone lines.
If it is inside, you can always swap the plugs for lines 1 & 2 to see if you have a programming issue. This assumes you have a TDA-50 or lower or NCP phone system. If you have a TDx-100/200/600 then you need to be a little more familiar with troubleshooting.
Carl
Posted on Sep 15, 2010
Phone displays error message "check tel line
The phone is not detecting dial tone on the line. Are you able to hear a dial tone? If not - disconnect the cable at the phone and plug into a different phone. If it works, then the problem is with the Panasonic phone - if it doesn't work - the problem is with the cable, jack, wiring, etc.
Mar 12, 2015 | Panasonic Lands Phones
How can I get set the outside line back on Line one and get the dial tone back?
try entering a 9 then the number you want .if that does not work try every number alone till you hear a dial tone
Jan 27, 2015 | Panasonic Lands Phones
I have a model KX-TG6445T PANASONIC 5 HANSET CORDLESS PHONE SYSTEM, THE PHON PHONE HAS NO DIAL TONE, AND SAYS PHONE IN USE. COMPUTER WORKS SO THINK IT IS A PHONE LINE AS THEY SHARE THE SAME LINE . HELP!
hi ... try this, change the cord in first.
if this don`t work: and make this test. whit another phone connected maybe in other place of the house(check first if you have dial tone ), plug the problematic phone, wait few minutes press talk on the other phone. if don't have dial tone the problem is the phone unit ,was impact by a lightning on the phone line.
few minutes after you connect the cord the line make a shortcut.
only an electronic technician can repair that, and sometimes is expensive.
Nov 30, 2013 | Panasonic Lands Phones
Panasonic DECT 6.0 shows "in use" but it's not. Why?
When I get this error, it's often a problem with the phone line wiring. Sometimes, it is the phone itself.
I like to use a spare corded phone and a new RJ-11 cord to localize the problem. First, try using the spare phone at the jack where the Panasonic base is plugged in. If you get a dial tone with the spare phone, try the new RJ-11 cable with the phone. If there is still no dial tone, then the phone needs repair or replacement.
If you do not have dial tone with the spare phone, try the test phone at another jack on that phone line.If there is dial tone, there is a problem with the first jack. You will need to open the jack and check the wiring. These are either keystones jacks or screw terminals. The keystone type require a special tool to press the wires into the terminal block. This is available at many hardware stores in the electrical wiring aisle (with the keystones and wires for whole house video/telecommunications access).
If you still have no dial tone, find the telephone access box. If you are lucky, that box has RJ-11 jacks so that you can test the line. If there is still no dial tone, contact your phone company. Outside line problems will be fixed by your provider.
If you have dial tone at the access box, you have a wiring problem somewhere inside.You can try to track the wires in any exposed area for signs of damage. You might want to call a professional to check the wires in the wall. Your phone company will do this for a fee.
I hope this helps.
(my own phones gave "Line In Use" when a contractor damaged a wire digging in the wrong spot and when mice got to the underground lines outside. Those problems were fixed by the phone company.)
Jan 29, 2013 | Panasonic DECT 6.0 Expandable Cordless...
Kx-td7896 no dial tone
hi re check might have wrong connections in the telephone connector ( box )
Sep 06, 2012 | Panasonic Lands Phones
Dial tone on speaker-phone but no dial tone on line 1
Either button mapping or no dial tone at the system cabinet. If your desplay sas CO1 and you have no dial tone, go to the sytsem cabinet ans swap the modular plugs for CO1 and CO2. If the No Dial Tone moves, "mus be sumpin wrong wit yo lines".
Carl
Aug 13, 2010 | Panasonic KX-T7730 Corded Phone
Can not get kx-t7885 to get a dial tone. The phone is paired with it's base, and will get the panasonic dial tone but not an outside line.
How are you trying to get an outside line? By dialing 9? If the host system happens to be a TA series, you have to tell it how many lines you have, or that you don't have lines that have hardware ports but no dial tone, since systems select outside lines from the top down.
From System programming, program 400 defines connected lines.
Carl
Nov 22, 2009 | Panasonic KX-T7885 Cordless Phone
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
Panasonic KX-T7630 Corded Phone Logo
75 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
