Question about Symbol LS2208 Handheld
When using the scanner to scan books in a library setting I have to push the enter button on the keyboard after I scan the book. Is there a setting so you do not have to hit the enter button; it will just do it automatic?
    Scholar:
  • 117 Answers
Hallo Jason,
yes, this can be done automatically, just by scanning three programming barcodes. Please follow the steps in the attached document.
https://docs.symbol.com/attachments/ADC-01244.doc
Posted on Sep 15, 2010
Testimonial: "This was a HUGE help for me. My libraian was jumping for joy after we got the scanner working correclty. Thank you!"
  • Max Quido
    Max Quido Sep 28, 2010
    You are welcome ;-)
How do i scan and send to email
Scan setup. create a folder on c drive of computer example called scan. then share folder with everyone and make sure it has read/write permission. Then on copier push button says user tools/counter then system setting/administrator tools/ address book management /new program / enter a name then go to folder smb then browse for computer select it. then will ask to log in. which is log in name and password that you use to log on computer with. Note user name needs to be letter or numbers only no symbols or spaces. Example user name: scanner password: scanner123 then select scan folder and press ok then press ok again to save setup.
Sep 30, 2014 | Ricoh Aficio Mp C5000 Color Copier - 129k...
Copying or scanning from books
Check in you scanner settings there should be the single sheet feeding setting check that is not selected
Jul 24, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
Why Symbol LS2208 keyboard wedge not scanning correctly?
Do you have more than one of this model scanner? If so, I would test a different one on the same computer to make sure it is not a computer issue. Be sure to test it in the same USB port to get an accurate test.
Having a second scanner would also allow you to switch out the cable connecting the scanner to the computer. The end of the cable which plugs into the scanner is an RJ45/Ethernet end. You will need a flat head screw driver to push down on the tab to release it from the scanner. Swap the cables and see if the problem follows the cable or the scanner. If it follows the cable, you can replace the cable for cheap. If it follows the scanner, I would plug the scanner into the working computer and reset the scanner to factory default using the Symbol Book of programming barcodes.
Try a different USB port with the original scanner.
You can also reset to factory default if you don't have a second scanner using Symbols book of programming barcodes.
Sep 20, 2014 | Symbol LS2208 Handheld
IT3800 keeps disabling my keyboard, also won't scan into the field
What operating system is running on the Dell PC? What version of the IT3800 User Guide are you using? With answers to these questions I might be able to assist you further.
Aug 26, 2014 | HHP IT3800 Handheld
How to Link Scanner from ricoh aficio 1232c
Download Twain Driver from ricoh site and you can use any softwere that suports twain scaning i use microsoft scan that comes with office 2003
Oct 18, 2009 | Ricoh Aficio 1232C Color Copier
QS6000 Plus with USB programing question
The document below programs the QS6500 Plus Scanner
R44-2805A Rev C
Available from
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
Jan 27, 2009 | PSC QS6000 Plus Handheld
Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Dec 18, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
Two extra digits at beginning
you can use the code book to clear any prefixes that may have been set on the scanner or you can try a factory reset (using the code book)
Sep 03, 2008 | Symbol LS2208 Handheld
Scanning - error: Sender's name not selected
Finally figured this out!!
Go to: UserTools - System Settings - File Transfer Tab - page 3 of 3 - Auto-Specify Sender Name - <ON>
Jan 30, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Symbol LS2208 Handheld Logo
1,037 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
