Question about Kodak EasyShare P850 Digital Camera
After turn on The Machine ask to set date/time and after it' freeze... I Bought another battery but the problem is continuing... I'm from Greece and after a telephone to German KODAK some tell me that "the Company stop to supply the P models camera" Thanks
  • 10,515 Answers
There are couple of things you need to check. Few camera's have reported to have this issue from memory cards. Try to ON the camera without a memory card.If that does not solve the problem, then pull out the battery for few minutes, say 5 - 10 minutes and then reinsert to check if that would make any further help.
If that does not help, either it is a corrupted firmware problem or some electronic circuit problem that has to be repaired. You need to look for either a local tech shop or KODAK.No doubt phone, email or chat service has been discontinued for this model,however, sometimes they could ask you to send the unit for repair.Cost of repair could be anywhere between $75 - $150 depending upon the exact fault.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 15, 2010
Date 01/31/14
Does it keep losing the date when you turn it off? or are you asking how to set the time and date?
If you're losing time and date when you turn the unit off, there's a coin cell battery on the main processor board that needs replacing.
If you just want to set the time and date - Press "SHIFT" and 12 lead keys at the same time. select "7" for date and time, use the return key to select date or time
Jan 31, 2014 | Ge Medical Systems Ge Marquette Mac 1200...
When i ON my digi camera its asking date n time every time???
You may continue using the camera without replacing the CMOS battery. You'll have to put up with the opening screen, and the photos you take won't have the proper date/time information if you don't set the clock, but otherwise the camera will operate fine.
May 21, 2012 | Sony DSC-W210 Digital Camera
As i turned on the monitor the screen shows CMOS WRONG PRESS F1 TO SETUP PRESS F2 TO LAOD DEFAULT VALUE
hi,
first of all check the main battery back of ur machine by unplugging from the mains power supply. if machine shuts off, then u have to replace the battery.and then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
if the main back up battery is ok, then another possibility is the CMOS backup battery of ur machine have some problem. that's why it loosed all the seted parameters. then u have to replace the CMOS battery of ur machine. normally 3V battery. then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
ok
Jan 13, 2011 | Dmm UT4000F Multi-Parameter Patient...
Error 00161 00163
[CHANGE YOUR CMOS BATTER WHICH IS INSIDE YOUR CPU CASE]
I do not think you fixed the CMOS battery - (backup battery = CMOS battery)
According to the error codes, you have a dead backup battery and the time is not set. Makes sense?
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Go to www.ibm.com Find and download the user manual, and the "hardware maintenance manual."
Do you know how to get into bios/setup?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key.
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1"
This will get you into the bios "setup." You should check the date, bootup order, etc, and reset.
I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
The "hardware maintenance manual" shows you how to maintain this machine, and it explains the meaning of the error codes.
This will get you started on looking for the manual:
http://www-307.ibm.com/pc/support/site.wss/multiplefiledownload.do?validate=true
May 16, 2010 | IBM ThinkPad 380ED
Need to reset time and date every time I turn on camera.
The backup battery needs to be replaced. This small button battery (CR1220) provides the power for your camera to 'remember' settings when you change or remove the AA batteries. Instructions for changing this battery are in the manual on page 191 (US version of manual).
You can view/download the manual here.
Sep 08, 2009 | Canon PowerShot SX100 IS Digital Camera
Asks for date and time
If it asks for date and time every time you turn it on even though you did set it last time - the internal battery is empty. You can change it if you have experience in soldering and repairs, otherwise - ask local Nikon or other camera service center.
Tom
Jul 28, 2009 | Nikon COOLPIX S710 Digital Camera
Hello my ibm thinkpad 600E will not come up. it says error 00161 and 00163. what do i need to do?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key. WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1" This will get you into the bios "setup." You should check the date, bootup order, etc, and reset. I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
According to the error codes, you have a dead backup battery and the time is not set. Error: 161
2. Backup battery.
3. System board.
Error: 163
2. System board.
Jul 14, 2009 | IBM Computers & Internet
Sony dsc-s90
Many digital cameras have a 2nd disposable battery to remember settings like date and time, and where to put the pictures, when the rechargeable battery is removed,, but I don't believe that is the case with your camera. possibly you are not actually getting the time set correctly, since the camera will continue to ask for time & date setting every time the camera starts, if it is not set properly when it asks. Concerning internal memory- Can you transfer the images from internal memory to the memory sick when you do insert it, or is there a chance that the memory stick is defective, and therefore the camera doesn't record to it?
Jun 19, 2009 | Sony Cyber-Shot DSC-S60 Digital Camera
R707wont work freeze of something problem
Sounds like the camera OS is running into a problem when it tries to store the new date information to memory. The data path could be corrupted, or it could be a faulty internal battery. Hopefully your camera still works when you bypass setting the time and date, so you can still use it.
Nov 14, 2008 | HP Photosmart R707 Digital Camera
Set Date
Use the time set key (M+)
Jan 20, 2008 | Canon Office Equipment & Supplies
Kodak EasyShare P850 Digital Camera Logo
21 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
