Question about Breville BKC700XL Stainless Steel
I have a Breville 700XL and it does not want to complete the brewing process. This happens mainly on the first use of the day. I insert the Kcup and the BREW icon flashes. But when I press BREW(for an 8 oz cup) it takes water from the tank and makes the appropriate noises indicating it is preparing to dispense the beverage but it never happens. If I turn it off and on 1 or 2 times I can get it to dispense but by that time it has has filled the internal tank so much that well over 16 ounces is dispensed.
4 Suggested Answers
SOURCE: Won't brew the full almount of coffee for the
My brewer is new. Only used it 5 or 6 times. It only dispenses about 3 oz of water. What is wrong?
Posted on Jan 02, 2010
cmccune04
  • 213 Answers
SOURCE: it won't brew when i put a kcup in but as soon as
Sometimes if the coffee is packed in to tightly or if your using a finer ground coffee it makes it harder to pump water through.
Hope that helps its just my experience. Mine does this too. I like my coffee strong so I understand
Posted on May 14, 2010
  • 58 Answers
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
Our cuisinart kcup coffee maker is leaking out the top of the machine. When it brews instead of a stream coming out of the pour spout, the machine leaks water all over the main brewing piece (where the k...
Take out the used kcup and GENTLY explore the holder fitting. There should be a sharp point in the bottom that punctures the bottom of the kcup to allow the brew to flow out the spigot and into your cup. There also needs to be a sharp point on the top to punch a vent hole for the water to enter. It they aren't both open, coffee and grounds will spray everywhere. Take it apart and clean thoroughly as well.
Nov 02, 2017 | Cuisinart Keurig B50 Single Cup Coffee...
My Keurig (one year old) does not brew a full cup (I have it set for the largest cup setting) and it only brews approx 4 oz. then stops.?
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Oct 03, 2010 | Keurig B100 Coffee Maker
When I press brew on my keurig it sounds like it's going to brew but nothing comes out. I did notice that the water flows back into to water resevior. What can I do to fix it?
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage.
Sep 20, 2010 | Keurig Platinum B70 Coffee Maker
Why does my keurig require me to set the process in motion 3 times just to get 1 regular cup of coffee.
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Sep 12, 2010 | Keurig Platinum B70 Coffee Maker
My Breville is only a couple weeks old. Over the ...
Try completely unplugging your pot and then plugging it back in. It is possible that this will reset the programming in your coffee pot. If this doesn’t work, I recommend calling Brevell customer service and they will either help you or probably send you another pot.
Nov 05, 2017 | Breville BKC600XL Coffee Maker
B-60 Keurig. Does not give proper fill. The steam is weak.Stops in the middle of the filling cup process. Works fine if I just run water through it. Have descaled numerous times per Keurig instructions. I...
Feb 10, 2010 | Keurig B60 Coffee Maker
Keurig b30 won't brew
Jan 08, 2010 | Keurig B100 Coffee Maker
KeurigB50 Coffee Maker will not brew. Gets to the
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
My keurig wont brew
Sep 03, 2009 | Keurig B60 Coffee Maker
Breville BKC700XL Stainless Steel Logo
165 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
