Question about Asrock 775i945GZ Motherboard
PC is switching off itself.Replaced power supply unit.Fault persist.
Please solve my Problem. I have xerox 242 with fault error code 010-328
the fuser has not reached its normal temperature. simple try to power cycled your unit. if this probably don't help try Switch off and disconnect the printer from power supply. Also disconnect any other units (PC etc) to it. Leave the printer disconnected for 30 minutes. It should do a soft reset itself, then restart it.
Jan 15, 2015 | Xerox Office Equipment & Supplies
Replaced power supply. No power to turn on or no sound
To which fault did you replaced the power supply board? For no power after the set is switched ON? Or it switches On first, and then switches OFF itself after some seconds? If the second said was the fault, the main board should be checked. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Timeslide" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 20, 2014 | Westinghouse Televison & Video
I have a asus striker extreme that shutoff by itself
did you check already the switch mode power supply unit of your pc? might drop the voltage or need to upgrade with higher wattage.
Jul 04, 2012 | Computers & Internet
Start up
mainly your power supply has the problem you need to replace first the power supply(SMPS) and then if the problem persist then the mother board
Jan 29, 2012 | Dell Inspiron 531s Desktop Computer
Panasonic rear projection tv switches itself off has done for two days now, have been told it could be the power source needs to be replaced can you help
Try plugging it into a power plug . Also see if u have any sleep function or child lock system enabled in it . Check for any damages in power cord coming from the tv back . Also try connecting the tv via a voltage stabilizer unit . if the problem persists , then the fault will be with the power supply unit within the tv which is to be repaired by an authorized service personnel only .
Jun 01, 2011 | Televison & Video
On switching on the PC, the processor fan runs for 1 second and then stops. Nothing else happens after this. I have replaced the power supply unit but the problem still persists.
Check all connections and cards to make sure that everything is secure, is your system speaker still connected? Does your graphics card require its own power (6-8 pin) check the 4 pin cable if intel.
May 03, 2011 | Intel Motherboard
Error 108
According the service guide, an F108 error is Line Monitor Failure
Correction action is:
(1) Recycle power to the cooktop (i.e. turn breaker off and on)
(2) If fault persists, test the line voltage supplied to the cooktop at the wall outlet. Voltage should read from 175VAC to 265VAC. If it does not, there is a problem with the power being supplied to the cooktop.
(3) If fault persists, replace power board
(4) If fault persist, replace logic (main) board
Search for my solution for replacing an element (JP939/JP969) for the basics to open up the unit.
Apr 09, 2011 | GE 30 in. Profile JP939 Electric Cooktop
Samsung syncmaster 226BW fails to wake up.
If pc not sending it to "sleep mode" or "power save" mode, then unit may need help of electronics technician to investigate the "internal switch-mode-power-supply" that may be going into "shutdown" mode after it detects a "fault condition" with itself or onother circuit.
12fixlouie
Sep 20, 2010 | Samsung SyncMaster 226CW 22" Monitor
Pc power-unit required for DELL
this may not be the power supply fault. this device depends on contact from front switch to start up.
check your switch on pc if u can give it a few hard taps. you can pic up these power supplys on ebay cheap enough, if all else fails
Nov 28, 2009 | Dell Dimension 2400 PC Desktop
Pc is constantly switched on & will not boot up
you may also have a fried motherboard unfortunately as the flashing light can refer to a power supply unit problem or motherboard fault
Sep 04, 2007 | Computers & Internet
Asrock 775i945GZ Motherboard Logo
44 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
