Question about Frigidaire Affinity ATF7000E Front Load Washer
My washer door alarm goes off and will not allow the washer to start. Appears to close well, Nothing caught in the door, will not wash. What is going on?
  • 213 Answers
SOURCE: Washer won't work... Period
the lid switch on the washer went bad. with out the lid switch working the washer cant do anything. its there as a safety to stop the washer when the lid is raise but when it goes bad it doesnt know if the lid is down or not so the washer wont come on
Posted on Nov 26, 2007
  • 1294 Answers
SOURCE: Zanussi Washing machine
Try some WD40 on the door switch.
Posted on Jan 25, 2008
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
  • 210 Answers
SOURCE: Alarm - Open door...
The door switch may be malfunctioning so it is not making good contact and therefore not sending the message that the door is closed.
Sgt 48
Posted on Jun 02, 2008
  • 1531 Answers
SOURCE: Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
Posted on Feb 06, 2010
Kenmore elite washer will not start
The problem might be that the black pin (about 3/8" long and 1/8" in diameter), that normally sticks out of the frame of the washer at about the 2 o'clock position, and which is pushed in when the door closes, has broken off. If this pin breaks off, the washer will not recognize that the door has been closed. In my opinion, the pin is most likely to break when you close the door and the door was not properly aligned with the door frame -- in which case the pin will be sheared off. Let me know what you find.
Jun 29, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
Feb 06, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Washing machine stinks
do the clothes stink too? or just the washer? if you have a crawl space check the washer drain it could be draining under the house...and vapors coming up through line......
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
Dec 21, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
35 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
