Question about Bunn NHB Coffee Maker
LOWER WARMING PLATE NOT HOT ENOUGH - Bunn NHB Coffee Maker
    Problem Solver:
  • 5 Answers
Change the TCO switch
Posted on Sep 15, 2010
The hot warning light on my rangemaster110 warming plate has stopped working but the warming plate still works fine
Two possibilities, either the bulb has failed, or the temperature sensor in the top has failed. Neither is likely to be an easy or cheap replacement.
May 17, 2015 | Rangemaster 110 (Gas) Kitchen Range
My Krups Grinder Brewer has stopped pulling water though the system. It just stays in the resevoir. Grinder part seems to be working fine.
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Oct 09, 2009 | Krups KM7000
Warmer lights up but not getting hot - Rangemaster Toledo XT
Hi Sally
I havd exactly the same problem. I contacted Rangemaster/Aga support line (0845 603 5312 if in warranty, 0870 789 5107 if not) and they told me the heating element was shot.
My cooker is 2 1/2 years old, so out of warranty, but they were good enough to send me a new cooker top (top left hand side only of course) free of charge!!!, I just have to get it fitted.
You have to replace the whole left hand side of the cooker top too - the burner that the wok goes on!
Good luck
May 08, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Cold coffee
Is it the coffee maker itself or the warming plate?
If it's the warming plate I would suggest geting a coffee thermos similar to the ones they have at IHOP and other breakfast places, it will keep your coffee hot all day if you first heat it up with very hot water and your coffee will not have the burned taste
Please answer if the answer works for you, thanks
Feb 13, 2009 | Cook's Essentials CEMB10TC
Using a thermal pot
I also bought the thermal carafe; before I could hack the warming plate, my wife set the "Auto Off" feature to 1 minute, which shuts off the carafe heater. The settings are preserved unless you lose power for an extended period.
The warmer does still warm through the brewing cycle but it doesn't overheat the carafe (IMO.) Hope this helps.
May 29, 2008 | Cuisinart DCC-1200 Coffee Maker
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
Warming tray too hot
You can either replace the warming element with a new one, or some people put 3 or 4 pennies on the top of the warmer tray. Don't laugh- this really does work!
Bunn UPR warmer too hot
Try connecting two elements in series. See if this keeps it hot enough. (One switch controlling both burners.) See if another brand of burner will fit in the hole. Check to see if the wattage is lower.
Feb 06, 2008 | APW Wyott Mr. Frank Hot Dog Broiler & Bun...
Mr coffee model isx43 12 cup
Turn the :Warming Temp." dial to the right, this is the hottest the heating plate will get and should resolve your problem. THedial is locatedjust under the clock.
Feb 02, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Warmer stopped working
the coffee maker brews but the pot warming plate isn't hot
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
Bunn NHB Coffee Maker Logo
159 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
