Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice maker not working,drinking water part is,do not see any water in ice tray
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 30, 2010
The ice maker on my Kitchenaid KBF320EVMS4 french door refrigerator stopped working. The drinking water works fine and I can hear the noise when the ice maker fills with water but no water comes in.
you can pop the cover off of the ice maker,on the module you'll see some letters,if you get a jumper wire and stick it into the T and H the ice maker should start to spin,if it doesn't the ice maker is bad,then remove the wire and stick it into the V and L,water should start to fill the ice maker,if it doesn't most likely you have a bad water valve,just get a piece of wire,strip off both ends to make a jumper wire.one more thing,check the fill cup and the fill line to see if there's any ice in there,if the water valve is bad water can drip through and freeze in the cup or fill line stopping the water from entering the ice maker,if there is melt it out with a hair dryer,also if you have to get in there with a hair dryer be careful with the heat on any plastic parts,you can damage it and don't heat the fuse on the ice maker wires,it's a black fuse built into the harness you can damage it if it gets to hot.you can go here to see your parts
https://www.searspartsdirect.com/model-number/KBFS20EVMS4/0593/0161000.html?searchType=modelSearch&q=KBF320EVMS4&searchTerm=KBF320EVMS4
Nov 22, 2017 | KitchenAid Refrigerators
I have a GE Refigerator (PSF26MGWA WW). the ice maker will not fill up with water. The tray heats up and the sweeper works. The fill solenoid for the ice maker does not work properly.The drinking water...
the ice maker is in control of the valve, however, the valve is one assembly containing the valve for the water dispenser and the one for the ice maker, take your model to the appliance parts store and get you a water valve assembly for your model number.
Dec 23, 2017 | GE Refrigerators
Dispenses water for drinking but not to make ice in ice machine
Your model refrigerator uses an electronic Ice Maker. You can test the Ice Maker by filling with tap water and let freeze sometimes they already have ice inside and shrinking because of defrost. If you can fill the trays with tap water and it freezes and dumps but does not refill with water the problem will be the water control valve. If ice maker does nothing and on then the Ice Maker is the problem. Try that first and let me know what you find, Sea Breeze
Feb 18, 2010 | GE GSS25JFM Side by Side Refrigerator
Samsung rs2555sl ice maker trouble
check to make sure that the tube that fills the ice maker is not froozen upo and causoing this problem
Feb 21, 2009 | Samsung RS2556 Side by Side Refrigerator
Ice maker not working, water not going in tray.
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
Ice maker problem
let it run its caused by stagment water in the system it will clear over time.
Feb 09, 2008 | Refrigerators
No water for ice maker
make sure wire is in down position this is like the on and wire up is off
Jul 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
Ice Maker Not Making Ice
There is no pump per say.. the water pressure is all that fills the ice maker and provides water to the drinking dispensor. The solenoids are also different, one activates for ice maker and the other for drinking water. The fastest way to check water flow is to swap the wires on the solenoids so the drinking water "power" will now power the ice fill solenoid. Once the plugs are swapped and you press the drinking water lever the ice maker should pour water out the fill tube. If that works then you know the solenoid, tube, etc. are all fine. I'd suspect then that the ice maker fill solenoid isn't getting power when it is suppose to fill. Let me know what this test result is.
Jan 23, 2007 | Samsung RS2534 Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
134 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
