Question about Pioneer AVIC-D3 Car DVD Player
No Function Menu on BT-Tel mode
The Function Menu Wont light up When in BT-Tel mode.
I can´t access those Functions.
Help!!
Thank you
I had the same problem, make sure either your wires are properly grounded if you have the bypass, or make sure your E-break is fully engaged, that was the issue with mine...
Posted on May 25, 2009
Hi there I have a Toshiba CT - 9969 and want to connect my laptop using VGA? What must I do and where do I switch to VGA on the remote? Thank you
connect to TV using VGA port and select device or mode to PC in tv menu. or using remote
press laptop fn +F4
or see display change button in FN buttons .press with or without FN button . if you use HDMI pls cinnect with HDMI cable and in TV pls select HDMI mode in video mode
There is a row of Function keys at the top of the keyboard on every Toshiba notebook. These give you quick access to some useful functions. To activate them, just press the FN button on the keyboard together with the function key to activate the following commands.
press FN+F4
Nov 16, 2016 | Toshiba Computers & Internet
You can find your operateing manual from http://koti.mbnet.fi/exuli/AvicD3.pdf
pdf reader required.
May 23, 2008 | Pioneer AVIC-D3 Car DVD Player
My canon ir 3300 touch screen panal not working.but matchin is start.only power light(green)glowing.
sol1) In service mode copier- function- clear- error. (Service mode can be accessed by pressing additional functions- 2-8-additional functions in quick succession).This should help
OR
Sol 2) Open the display unit of your copier and take it for dry soldering.
Note:- expert help may be required for step 2. don't try yourself.
Oct 30, 2013 | Canon Ir 3300 B/w Copier image Runner...
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
BMW Bluetooth related issue. The BT menu would not initiate - menu will show up with TEL,BC & CONFIG but the telephone icon would...
Ismail,i have been wrong before BUT i dont think the bt kit is compatible with the bmw system,(same as Audi/VW)the Parot or vodaphone system is the ones we used to fit to for customers who requested handsfree. regards.Geoff.
Nov 24, 2010 | 2006 BMW 3 Series
NEED DIRECTIONS TO TURN ON FAX RECEIVING MODE
press menu and fax function and choose tel,tel/fax or fax
May 24, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Jul 23, 2009 | Konica Minolta Office Equipment & Supplies
Accessing TV Menu withough original remote
No you need the remote ! and even most universals will not do that function for you either!
You can order an orignal replacment remote from www.remotes.com and that will let you access all of the tvs functions!
I hope I was of big help!
Please rate my FREE response!
Thank You!
Jan 17, 2009 | Toshiba MD20FP3 Combo
Mfc 8460n dr mode in use
The message DR mode in use or BT Call Sign On will appear on the display of the Brother machine if you attempt to change the receive mode from Manual to another mode when the Distinctive Ring feature (BT Call Sign) is turned ON. If you want to change the Receive Mode, set the Distinctive Ring feature (BT Call Sign) OFF.
  1. Press Menu or Menu/Set.
  2. Select Fax => Miscellaneous or Tel Service => Distinctive or BT Call Sign.
  3. Press the Up or Down Arrow key to select off. Press OK or Menu/Set.
  4. Press Stop/Exit.
Jul 16, 2008 | Brother Office Equipment & Supplies
He2415u convection range
1. Access SELECT FUNCTION menu
2. Turn knob clockwise until desired language is displayed
3. Touch start to accept a language change
To access SELECT FUNCTIONS menu, touch and hold COOKING MODE touch pad for 5 seconds
SELECT FUNCTION is displayed:
1.Turn knob to desired feature
2.Press START to choose any function, and turn knob to choose any sub-functions
3. After selecting feature, touch OFF
Jan 02, 2008 | Siemens HE2415U Electric Kitchen Range
Pioneer AVIC-D3 Car DVD Player Logo
91 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
