Question about Frigidaire Dishwashers
My Frigidaire is old, at least 15 yrs. Model # fdb635 or #fdbc45 , it is 29 x32 1/2 The detergent dispenser does not open. When I open the door and manually open it still does not wash right. Cups and glasses are not clean on inside, and leave spotting on glasses and other dishes. I'm not sure of my timeing of opening dispenser door. This is a white dishwasher. High energy . I do not have a manual to refer to I would appreciate your advice.
  • 641 Answers
SOURCE: Dishwasher won't dispense soap
The dispenser's unit should be replaced. You can try as well to operate the dishwasher while putting the powder detergent or the tablet on the dishwasher's bottom and if you will get good results, to opereate the machine this way. Good luck!
Posted on Sep 06, 2007
  • 409 Answers
SOURCE: Detergent trouble
hi there,
sounds like the detergent dispenser is not working properly.
are the rest of your dishes clean? in other words, is there any food residue on them?
check the dispenser and make sure that there is nothing visibly wrong with it.
if the problem still persists, replace the dispenser.
Posted on Sep 13, 2008
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
rickzilla
  • 706 Answers
SOURCE: Dishes not getting clean, white film
Hello cljjtm,
You will need to clean the wash arm and unclog the spray holes.. use white vinegar to break down the soap deposit and a sharp metal tool such as an awl to free these holes up from any build up.. white vinegar may be applied while unclogging the openings..
Then, once the spray arm holes are freed of deposits..Start with an empty dishwasher.. and then start a wash on the hottest available setting and then after a few minutes of it cycling.. pause it and add a cup or two of white vinegar to the wash ( the white vinegar should break down any soap residue and allow it to be rinsed away)..once complete.. use about 1/3 less detergent than you have been. See if that gets your DW back in working order.. Hope that helps..
Regards,
Rick
Posted on Feb 16, 2009
  • 677 Answers
SOURCE: dishwasher does not clean dishes and leaves spots on everything!!
The problem is hard water that is leaving the spots. There is a fantastic product out called the dishasher filtration system. It filters the water going into your dishwasher and works amazing. It is very affordable and very easy to install. You can get it at www.dishwasherfilter.com.
Posted on Mar 14, 2009
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Model number FDB4050LHB1, is very loud when operating and does not dispense cleaning tablets or liquid, cycles through but does not clean, and cleaning tablet or liquid still in door, tablet door will not...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 28, 2010 | Frigidaire 24 in. FDB635RF Built-in...
The dispenser door opens but the detergent is not released into the dishwasher. After the cleaning cycles are done, I open the dish washer door and the detergent is still in the tray. What could be...
heatman101 //../
Nov 25, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Jan 20, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer wont dispense cubes, only crushed ice
I had this same problem for a few days. I opened the door & played with the ice dispenser hole and it ended up working again
Dec 19, 2008 | Frigidaire FSC23F7D Side by Side...
Dishes won't come clean
If you have dishes (typically cutting boards or really tall dishes) that block the dispenser door from opening, the water cannot wash out all the detergent during the wash cycle. Check to see that after loading the dishes, your detergent door has clearance.
Aug 26, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
