Question about Microwave Ovens
Maytag MMV4203 turntable not turning - Microwave Ovens
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 15, 2010
Maytag microwave turntable doesn't operate
Does everything else work?? If so, its just the turntable motor, simple to replace. there are three or four screws under the bottom. UNPLUG the microwave first.
Double check before ordering...but ..
Here is the one you need:
Turntable Motor DE31 10172C
Oct 01, 2017 | Maytag Microwave Ovens
Maytag model MMV4203 display shows SE
same thing as Samsung - shorted key - google manual
Feb 01, 2016 | Maytag MMV4203D Microwave Oven
Turntable will not qwork
The turntable motor is defective and must be replaced, I suggest contacting the Maytag people for service.
Jan 26, 2011 | Maytag MMV5208W Microwave Oven
The turntable in the microwave won't turn at all. Unit is <1 yr old. The turntable on/off selector doesn't help it. Any suggestions?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Nov 14, 2010 | Maytag MMV4203D Microwave Oven
Microwave will not heat. The light comes on the turntable turns
Basic Microwave Oven TroubleshootingTips
heatman101/./,/,
May 16, 2010 | Maytag MMV4205 Microwave Oven
Turntable will not turn with glass turntable on it
Make sure the platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced.To replace either part visit the web site www.partsdirect.com If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Microwave Ovens
Maytag Microwave 1150 Help
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Apr 05, 2009 | Maytag MMV4205 Microwave Oven
Over the range microwave turntable has stopped turning
You give very little information Toni, but it seems the turntable motor is defective. If you are comfortable with this you must remove the cabinet (probably six screws in the back) and locate the motor at the bottom of the unit. Check all connections and connect the motor to a 120 volt source. If it is defective, order a new one on-line from the manufacturer. Your other option is to replace the oven. This would be my suggestion unless it is still in warranty.
Ray
Nov 20, 2008 | Maytag MMV1153A Microwave Oven
Maytag mmv1153BAB built in plate not turning
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either is a pretty simple job.
You need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 28, 2008 | Maytag MMV1153A Microwave Oven
Turntable no longer turns
Your problem is either a weak or slipping motor or a broken / cracked turntable coupler. If the coupler turns loosely without actually engaging the motor, it is bad. If the coupler is good or looks good, it's probably the motor. One test of the motor is to firmly grab the shaft with pliers and try to gently turn it. It should turn with some resistance and make a whining sound as it turns, since it is a highly geared motor. If the motor turns very very freely - or not at all - then it is bad. You can see an exploded diagram and order parts via the Jenn-Air (Maytag) Web site at http://services.maytag.com/abs/PartsStore.do?nextPage=psstartpage You will need to enter your full model, which is apparently one of the following: JMC7000ADB JMC7000ADQ JMC7000ADW Referring to the CABINET-BASE-CAVITY diagram found there, you will see: - REF 23 motor - REF 27 coupler One of those is likely the culprit.
Dec 06, 2006 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
109 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
