Question about Mercury Health & Beauty
How do i adjust the mecrcury numbers when it is off?
    Scholar:
  • 192 Answers
God day! I have checked with 4 major brands and the merc level is not adjustable. One company, Omron, told me that it is for safety and they did not want the merc played with..... Hope this helps, if so, please remember to vote.... Take care... Guy :)
Posted on Sep 15, 2010
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Adjust the chim on a model ffw 5000qw drigidaire washer
Hey friend, thank you for your inquiry!
I see that you would like to adjust the chime on your Frigidaire washer. I researched the model number you provided, FFW5000QW but was unable to locate any information on it. Could you verify the model number for me please? You can locate your serial tag (which lists your model number) on the door frame of your washer with that information I can double-check to verify if the chime can be adjusted. -Matt
Sep 29, 2014 | Frigidaire Washing Machines
Its a 92 1.4 RT. Noisy tappets. Am about to change oil and filter and wish to check tappet gaps as well. Please assist.
12th inlet 14 exhaust for the valve clearances ,adjust by the rule of nine that is number one down adjust number 8 -----number 2 down adjust number 7 ---and so so so every adjustment adds up to 9 ,simple when you know how isnt it
Aug 24, 2011 | Renault Le Car Cars & Trucks
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
You said youknew the torque specs for my rocker arms on the 92 chevy s-10 pickup 2.8 liter v-6
  1. Crank the engine until the mark on the Harmonic Balancer lines up with the "0" mark on the timing tab and the engine in the number one firing position. This may be determined by placing fingers on the number one valve as the mark on the damper comes near the "0" mark on the timing lab. If the rocker arms are not moving, the engine is in the number one firing position. If the rocker arms move as the mark comes up to the timing tab, the engine is in the number four firing position and should be turned over one more time to reach the number one position.
  2. With the engine in the number one firing position as determined above, the following valves may be adjusted:
    1. Exhaust: 1, 2, 3
    • Intake: 1, 5, 6 (Even numbered cylinders are in the left bank; odd numbered cylinders are in the right bank; when viewed from the rear of the engine).
  1. Back out the adjusting nut until lash is felt at the pushrod then turn in the adjusting nut until all lash is removed. This can be determined by rotating the pushrod while turning the adjusting nut (figure 7). When the play has been removed, turn the adjusting nut in one and one-half additional turns (to center the lifter plunger).
  2. Crank the engine one revolution until the timing tab "0" mark and vibration damper mark are again in alignment. This is the number four firing position. The following valves may be adjusted:
    • Exhaust: 4, 5, 6
    • Intake: 2, 3, 4
Jun 05, 2011 | Chevrolet S 10 Cars & Trucks
HOW DO YOU SET THE CLOCK ON TOYOTA COROLLA AE112R ASCENT HATCHBACK PLEASE
While holding the AM button, adjust the time by pushing the NUMBER BUTTONS 1-2.
Hour adjustment......NUMBER BUTTON 1 Minute adjustment...NUMBER BUTTON 2
There you go :)
Oct 26, 2010 | 2001 Toyota Corolla
Do the throttle position sensor need to be set after changing it ? if so what number
If the 8th number on your VIN# is (1), no adjustment, just replace it, but if 8th number on your VIN# is (L), needs to be adjusted to .50 (1/2) volt, with key on engine off, with volt meter, one wire will have 5 volts, that's computer out put, the next wire is the one you get the reading to adjust, adjust to .50 volts, the last wire is ground, don't worry about that one.
Sep 17, 2010 | 1994 Oldsmobile Eighty Eight
Copies have dark areas extending from top to bottom of page
try to adjust the exposure adjustment to adjust that press the lock lever open to clamp shell then adjust the rotating vr there is a number indicate adjust to lower number then try to test a copy if its work
Dec 31, 2009 | Canon PC-920 Black and White Copier
Rebuilt engine valves not adjusted.1970,s model 350 chevy i need to know the proper way to adjust before start up
you need feeler guage, youl need find the valve clearence to set it and adjust each one by using the rule of 9
Sep 21, 2009 | 1983 Chevrolet Chevy
How do you adjust aftermarket roller rocker arms
well first you need to know the firing order...if it's a small block chevy the firing order is 18436572. You need to write the second four digits underneath the first four digits.
so it looks like this 1843
6572
This will let you know which rocker to adjust...turn the engine over by hand using a rachet on the crank shaft bolt by the harmonic balancer until you get both rockers for number 6 cylinder moving at the same time. Now you may adjust the clearance for both rocker for number 1 cylinder. Then crank the engine over by hand again until number 5 cylinder rockers start to move. Now you can adjust the clearance on number 8 cylinder. You will need to know the manufacturer specs for the valve clearance...continue until all rockers have been adjusted.
Note: The engine should be warm when you make the adjustment.
please rate this.
Sep 20, 2008 | Chevrolet Camaro Cars & Trucks
Health & Beauty Logo
49 people viewed this question
Top Mercury Health & Beauty Experts
D. E. Hev
Lawrence Oravetz
Are you a Mercury Health and Beauty Expert? Answer questions, earn points and help others
