Computers & Internet Logo
Posted on Sep 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to print pdf files - Computers & Internet
Anonymous
Level 2:
Scholar:
  • Expert 179 Answers
  • Posted on Sep 15, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
179
Questions
0
Helped
27749
Points
351
Right click the pdf file and open the files in microsoft word
Print pdf files
What program are you using to view/print PDF files? Does the PDF file allow printing? It's possible to create a PDF file that disallows printing.
2helpful
Cannot print pdf file on x1270
If all else prints fine except when printing PDF files, try to update your Adobe Acrobat. Then, after the update is successful, try to print your PDF file again to verify that the problem is fixed.
3answers
How to print PDF File to Epson LX 300+
Open the PDF on your desktop, click File then print.
4helpful
4answers
I am unable to print pdf documents on my Image Class d880 printer. I used to be able to...but am not able to anymore. Any reason why this is happening?
Maybe your pdf is protected by print password, in this case, you have to use the pdf password remover to remove the print permission.Here is tutorial on how to remove it on windows:
http://www.pdfpasswordremover-mac.com/pdf-password-remover.html
Cannot duplex print pdf files. No problem for over 2 years until now. Word docs OK have tried changing printing settings and default but problem persists. Advice would be really appreciated. Thanks
Printing PDF files without special software can be a problem, if you print a lot of files of different formats and need to deal with a few printers.
Total PDF Printer from Coolutils is a program features a lot of printing modes and adjustable parameters that will help to optimize the process of printing PDF files. To save the paper, it offers ability to print PDF files in duplex mode, i.e. print PDF pages from both sides of paper sheet.
You do not need to turn each sheet by your hands, as the program changes printer settings so that this process is automated.
Total PDF Printer is a perfect suit for personal or professional use for printing PDF files. It automatically connects to all printers enabled in the system and redirects printing tasks to the trays you specify.
Print PDF Files In Duplex Vertical
1helpful
Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
4answers
Printer
try printing a test page. Make sure you have the right driver for your printer. Make sure all connection are secure and tight.
3helpful
2answers
Printing PDF files
I had this problem after I had fixed a problem printing from Quicken. I was able to print from Quicken by changing the print option in Windows -- mine was set to "Spool documents" and I changed it to "Print directly from printer" -- the advice I was given was to change it from whatever it was set at to the other option. For printing a PDF file, I changed it back to "Spool documents" and it allowed me to print the PDF file. Try this and see if it works for you -- click the Windows Start button and select Settings, then Printers and Faxes. Right click on the selected printer and select Properties. In the properties window look for a setting to print directly to printer or spool documents -- mine was under the Advanced option. Try the option not currently selected -- in my case, I changed it back to Spool documents with Begin printing immediately -- and then try to print a PDF file. It looks like I will have to toggle back and forth when I am printing from Quicken and when I am printing a PDF file. Hope this works for you.
Grand Canyon Tech
Grand Canyon Tech
