Question about Toshiba Satellite 3005-S304 Notebook
Says low abttery,critical battery, please plug into a power source... and then it hybernates.... the issue is, it IS plugged int o a power source!
  • 72 Answers
The problem is the power cable please check the cable and if the cable is working then change the battery
Posted on Sep 15, 2010
Hp dv5 not charging or booting up
Try this,
remove the battery and try with the ac adapter. Generally we trying to see if its battery or ac problem. Laptop should start cause the source of the power is the 120v electricity converted for laptop use through the adapter.
If its still not starting, then its adapter issue, just buy another one from a local computer store or amazon according the model of the laptop
Jan 12, 2014 | HP Pavilion dv5-1138nr Notebook
My acer aspire one pav70 went into hibernating mode . how do i get it out of hibernation
It could have gone into hybernation for more than one reason.
Either it has been programmed to or the battery is low. Either way pressing the power button momentarily will get it out, if the power supply is plugged in or the battery is charged.
To remove the hybernation option, right hand mouse click on the battery icone on the desktop and change you power settings.
Hope that helps.
Nov 28, 2010 | Acer Aspire One Netbook
Have Toshiba Equium L300, has just stopped working, no power getting to laptop. can anyone advise if this is abttery or power cable? cheers
Remove the battery and plug in the charger(Power Cord).
Try turning on the computer.
If it starts, its an issue with the battery.
Battery may not have charge or the computer is not charging the battery.
Try replacing the battery before checking the computer.
If not, it can be either the computer or the charger.
But try checking it with a different charger before taking the computer for repair.
Oct 29, 2010 | Computers & Internet
My laptop is not switching to AC mode even when plugged into Ac Power outlet. I work on battery mode and after full battery drain, the laptop goes into hybernation...once into hybernation it starts...
1. You may possibly have a faulty power supply adapter. Contact the manufacturer and see if there are any call backs on the power adapter for you laptop unit
2. you may also have a damaged connector at the laptop connection. This will require repair by a technician.
Aug 03, 2010 | Computers & Internet
Acer Aspire One PC Notebook- Mini 1GB, WXP
This sounds like the laptop is faulty if within minutes the laptop is totally drained of power from a so-called full charge.
Because the laptop is new then I recommend that you send or take the laptop back for repair or replacement as it's still covered by the manufacturers warranty.
Regards.
Jul 22, 2010 | Acer Aspire One PC Notebook
Battery is low / critical please switch to power
ok, how old is your laptop battery?, if it is over 2or 3 years and you always have it connected to your laptop while the power adapter is plugged to the wall when you use it, it must be time to replace it.
While on the other hand, if you have Windows XP Service Pack 2, then there's an issue problem between the Operative system and the battery itself. Here's a hotfix posted on the Microsoft's website and you should only use it if the problem meets this description http://support.microsoft.com/kb/938961 . Good luck.
Jan 03, 2010 | Acer Aspire 3000 Notebook
It says the battery is dead
if the abttery goes dead sometimes mp3 players have a usb plug for the computer plug it in and hopefully it will charge
Sep 26, 2009 | Sony NWZ-E436F MP3 Player
Power
Hi Mike..
This case mean ..there is loss of power from the Chagring adapter or the power socket ..
so check the adapter with another Dell just to check if its charging or not...
else the power socket which u plug the adapter ..and that's what i guss quz u said the critical light was blinking,,
best luck
Dec 01, 2008 | Dell Inspiron 1501 Notebook
Samsung V25 Laptop When it is powered up nothing is showing on the screen although the power light is on and you can hear a noise. This has happened before and it just came on.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Jan 07, 2008 | Samsung V25 CXTD 2000 Notebook
Toshiba Satellite 3005-S304 Notebook Logo
135 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
