Question about Acer Ferrari 4005WLMi Notebook
Microphone problem ....
I have just downloaded Skype - only to find that there is a problem with the Audio Recordings Setting and\or Microphone Setting
i.e. I cannot get my system to 'hear' me.
Can you help?
Many thanks. Kat.
  • Dung Nguyen May 11, 2010
    what is the make, model and your OS
  • 50 Answers
Check control panel, sounds and audio devices properties, and configure them and Skype as required.
Posted on May 17, 2008
How to install skype
If you choose to install skype or another messenger program you will have the options to join make an ID or if already a member to sign in an Id must consist of letters and numbers just one number will do the Id must be unique skype will automatically search to see if your Id you have made is available eg: clogsy9 http://skype.en.softonic.com/universaldownloader-launch http://majorgeeks.com/Skype_d4245.html
Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver Open skype go to tools from the drop down list select options scroll to audio settings you can make a free test call before you try to make a call make sure the microphone is using the same as your computers audio You can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also Click start control panel sounds and audio devices audio and also voice its the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call also Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also Select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it Hope this helps. connect your phone to the internet download skype for mobile phones
http://download.cnet.com/skype/3000-10440_4-75312694.html
Jan 13, 2013 | Axis M1113 Network Camera - Network camera...
My micphone seem not to work on the other end can you help.
Dear sylvers11
There are many cause for your microphone is not working.
1)if there are some hardware problem in your microphone than solve it from electrician.
2)check your microphone setting in pc.enable audio input .check you installed audio driver or not.
3)if all things is ok than problem is in your skype.check your skype setting.try skype test call services.
4)reinstall your skype if above tricks not work.
Feb 10, 2011 | Skype IM
How can i get my in built microphone to work with skype on my acer 4732z notebook
If you are using skype
open skype go to tools from the drop down list select options scroll to audio settings make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment or
Jan 16, 2011 | Computers & Internet
The microphone on my C200 webcam won't work. I have installed the software and also downloaded from the website - several times. I have also changed USB etc. The video works but not the microphone. I...
You may just need to manually select your mic. Go to this free video mail site. Click on the mic icon and then try the choices in the drop down list. Record and play back brief recordings until you can hear yourself. Once you know the mic that works select it in Skype or other software program. It is usually under Settings, Audio.
Dec 23, 2010 | Logitech Webcam
Skype video call failed
Hi this seems to be a regular problem with skype im not sure what he problem you have encountered ? so here is a guide
Dec 14, 2010 | Computers & Internet
Download camera to enable me to set up skype using Microsoft LifeCam VX-2000 onto Mac OSX leopard Version 10.5
open skype go to tools from the drop down list select options scroll to audio settings make sure the microphone is using the same as your computers audio you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment or control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make the right adjustments
hope this helps
Oct 26, 2010 | Microsoft LifeCam VX2000 Webcam
My internel microphone doesn't work with Skype -
You need to check the Microphone setting in Skype.
Open Skype, Click on Tools - Audio Settings, then in Microphone settings click the down arrow and select the built-in microphone then save the settings.
If the microphone you selected doesn't work then select a different one.
Jul 04, 2009 | ASUS W5Ae PC Notebook
Microphone not working
Hello.
1. Audio settings all versions
Skype:
Skype-->Main window…..>Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard (AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
2)Check if your micro (pink) and speaker (lime) jacks are really correct and fully inserted!
They sometimes stuck.
For test only you can use earphone instead of microphone for Line In.
Standard micro in Line In will NOT work.
Go to:
Start
Programs
Accessories
Entertainment or go to
Volume Control; right click on loudspeaker icon in Task Tray
Options
Microphone
Scroll down
Check "Microphone"
If the bar "Microphone" is available, the microphone is detected by Windows now go on
(If not, Windows has a problem with your microphone)
Just to check if your microphone is broken or bad, you can use your headphones instead. They really work!
Which one L or R is microphone now, I think it's L
Check "Advanced properties"
Check Micro "Advanced"
Open
Check "20db boost" or "1.MIC boost" depending on language version
Volume level can be left in any position.
Mute microphone!!!
3. Check audio now on windows base.
Start
Programs
Accessories
Entertainment
Soundrecorder
4. Once done, test with Skype Test Call echo123.
Good Luck
Please Vote.
Jun 17, 2009 | Dell Dimension 3100 PC Desktop
Cant get my mic to work
DOWNLOAD NEW DRIVER FOR IT ,,GO TO THE DELL DRIVERS SITE
May 15, 2009 | Dell Inspiron 1521 Notebook
My skype sound keeps fading in and out.
Change skype sound setting. TO do that :
Take Tools from the menu bar.
Then select options.
When a new window opens choose audio Setting.
Then below microphone volume untick - "Automatically adjust microphone setting".
Then drag the volume to maximum.
Mar 15, 2009 | Skype IM
Acer Ferrari 4005WLMi Notebook Logo
120 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
