Question about Carrier XCD121D Air Conditioner
Where can I get mode control sw. - Carrier XCD121D Air Conditioner
  • Carrier Master
  • 17,130 Answers
You might have to source the same type only from Carrier without trying to put in a replaccement type.
so check on their main website
www.carrier.com
Posted on Sep 15, 2010
Testimonial: "Thank you for help me get the solution of this problem."
How can i change the time
Note how the buttons around the outside edge of the watch match up to the compass directions on the outer ring of the watch face. Use the butttons on the NW, NE, SE, and SW positions.
  1. To enter time setting mode, press and hold NW until the Seconds start to flash. (You can exit time setting mode at any point by pressing NW twice)
  2. Release NW and press SE to reset the Seconds to 00.
  3. Press SW and the Hours will start to flash.
  4. Set the hour by pressing NE (down) or SE (up) Press the lower button to move up and the upper button to move down.
  5. When the hour is correct, press SW and the Minutes will flash.
  6. Set the minutes by pressing NE (down) or SE (up)
  7. When the minurtes are correct, press SW and the 12/24hr setting will flash.
  8. Switch between 12hr mode and 24 hour mode by pressing SE.
  9. Press SW and the Year will flash.
  10. Set the year by pressing NE (down) or SE (up)
  11. When the year is correct, press SW and the Month will flash.
  12. Set the month by pressing NE (down) or SE (up)
  13. When the month is correct, press SW and the Day will flash.
  14. Set the day by pressing NE (down) or SE )
  15. When the day is correct, press SW and the seconds will flash again.
  16. Exit time setting mode by pressing NW twice.
This is a complex watch. You can download a manual here http://www.casio.com/products/archive/Watches/PRO_TREK/SPF40-1V/
Apr 02, 2014 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Front defrost not working
as always, check fuses first.
then scan this car, it will show, mode motor errors. huh?
those are damper. in the heater box.
there are 2 fail points (besides wires)
the control is bad,
or the damper is failing.
The FSM covers this 100%
or at alldata.com
what tech does is makes sure the control sends the signal
the damper (there are 3 types used on all cars)
if its damper motor , the FSM shows the damper tests.
which are unique to Toyota. and a spec, year, 2006.
the mode damper is failing.
the only question is why,
the answer is simple tests. detailed in all FSM of all cars made.
here ill look your up to see which of the 3 type class it is.
your car has a ACC brain, a/c controller, this controller runs the show.
it gets your inputs from the defrost switch and then sends signals
to the mode motor.
FSM quote
Air Vent Mode Control Servo Motor ControlWhen the mode select SW is pushed, the ECU in the A/C control assembly activates the air vent mode control servo motor.
The servo motor rotates to the position (FACE, BI-LEVEL, FOOT, FOOT/DEF, DEF) selected by using the mode select SW,
and moves the damper.
In auto mode, A/C control assembly controls the damper to move to the best position for the conditions without operating the
mode select SW.
I SAY SCAN iT
using any scan tool that suports full Toyota. full scans including
extended factory codes..
i say buy one.
here is one.
http://www.amazon.com/gp/product/B001QIUGVI/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
owning complex cars, and DIY, you need a real scan tool
or just guess.
Feb 18, 2014 | Toyota Prius Cars & Trucks
Auto climate control
I would have someone check the automatic system - the minus temp will keep the system from working because the body computer thinks the outside air is below zero. The sensor for outside air may be defective.
Aug 26, 2012 | 2001 Chrysler 300M
I have an Elation FC400 DMX foot controller and an Eliminator ED15 Dimmer pack (8 plug ins). Cannot get controller to do anything when Dimmer Pack set to Slave mode, Dimmer pack works fine on Programs...
In slave mode the second pack should be controlled by the first pack in the chain, not the foot controller. I think you probably don't want to be using slave mode if you are using external controller... try setting the packs to the same address so they both track the foot controller.
Jul 27, 2011 | American DJ Dmx-16 Sw System 16 Ch Dmx...
I need a driver/SW for DELL D610 sleep mode, Pls. send me download version and installation instructions
Hi
Sleep mode don't need drivers,
It's pre-configurations are pre-installed in the Control Panel > Power Options
Go there, try to adjust and test the options for sleep mode ( when to sleep: close screen, press power button ,, ) and after how much time ..
Please,tell us your results
Good Luck
May 19, 2011 | Dell Latitude D610 Notebook
Vsc, engine and track off light are on the dash board, what could this indicate?
VSC is for "Variable Slip Control" and TRAC is for "Traction Control". Your car is equipped with an antilock brake control system that is also equipped with VSC and TRAC. If these lights are staying on all the time, it is an indication that there is a malfunction in the system and your car will not function properly in the event that you get into a situation where evasive maneuvers are needed and/or slippery conditions could cause you to lose control of your vehicle.
SYSTEM OUTLINE
The vehicle could be in an extreme over steering or under steering tendency due to unexpected accidents, road conditions, vehicle speed, or by other external factors. In such a case, this system automatically controls the engine output and the braking to each wheel, to decrease the extreme over steering and under steering.
  • To decrease extreme over steering tendency When the system determines that the over steering tendency is large, the system applies brakes to the outer wheels according to the degree of over steering, and creates a moment towards the outer side of the vehicle, to decrease the tendency of over steering. Also, when the brakes are applied, the vehicle speed decreases while the stability increases.
  • To decrease extreme under steering tendency When the system determines that the under steering tendency is large, the system applies brakes to the front or rear wheels according to the degree of under steering, to decrease the tendency of under steering.
  • VSC OFF SW The SW to send the VSC system into OFF mode. When the SW is pushed after starting the engine, the system will be in OFF mode, and the VSC off indicator light will turn on. When the SW is pushed again, the system will be in standby mode. When the engine is stopped and re-started, regardless of the VSC OFF SW, the system will be in standby mode.
Information to the driver
The VSC system informs the driver when the tire grip is about to exceed its grip capacity, by blinking the slip indicator light and turning on the buzzer. Accordingly, the driver is informed to drive more gently.
Diagnosis of this problem needs to begin with a scan of your VSC and Traction Control and ABS control modules to retrieve fault codes. It could be anything as simple and painless as a malfunctioning Wheel Speed Sensor, or something as expensive as a damaged Hydraulic Control Unit.
Nov 23, 2010 | 2003 Toyota Avalon
How access the service menu
On the front video input terminals there is a small hole to the left of the terminals use a small thin metal rod or paper clip to push the factory mode button.
SD-533HD5, SD-643HD5
7.1.4 The method of power-on (for service)
When removes the Front Grille, remove the
connectors from POWER SW Assy, FRONT INPUT
Assy and FRONT LED Assy and remove the Grille.
This set is not turned on the power in the state that
removed the connectors.
At this time, connect a connector that connected to
the POWER SW Assy to the SHORT Assy, and can
turn the MAIN POWER SW to ON.
Be careful there is a case to be turned on the power
in the state that front side of this set opens.
In addition, the front input and front key do not work
because each Assy does not connect it, but the
remote control unit works in the same way normally.
There is a Factory Key on the FRONT LED Assy.
When enter the Factory mode, transfer a code with
the remote control unit or connect the FRONT LED
Assy. (Turn the Main Power SW to OFF when
connects it.)
SHORT Assy
The connector of POWER SW Assy
The connector of FRONT INPUT Assy
and FRONT LED Assys
Factory Key
Nov 19, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
No matter what picture setting is selected the camera, Sony DSC-W50, it will only take video. Does anyone know how to fix this problem? Thanks
I think mode selector dial is not working in your DSC-W50 that is why camera is set on video mode.
Replace mode selector dial as mentioned in below image, part number is...
1-479-584-11 CONTROL SW BLOCK (SW110T) (for SILVER color)
1-479-584-21 CONTROL SW BLOCK (SW120TB) (for BLACK color)
Available in Part Store.
Thanks.
Oct 20, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Resetting the demo mode
turn off with OFF sw.
Press WARMER / COLDER sw for 5 seconds
While maintaining warmer / colder turn ON with ON sw.
SHOULD NOW TURN ON
May 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
DSC-S40 , my camera wotn switch mode.
If you opened and unable to find the switch, then the switch might be snapped, or the sw slider was not aligned to the sw itself. you can find it by aligning the sw slider of the back cover to the main board, its a very small switch soldered on the board near the upper portion of the LCD panel. If you find it, slide it to leftmost, at the same time, move also to the leftmost the sw slider at the back cover. Assemble it carefully, thanks
Aug 13, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Carrier XCD121D Air Conditioner Logo
41 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
