Question about GE DCSR483EA Electric Dryer
My dryer was making a loud squeeking noise while drying, now it won't start, I can hear it trying purring but than it does not start, help!
    President:
  • 2,468 Answers
If you can hear the motor running,and if this unit does not have a belt shut off switch,the motor will run even if the belt is broken,the squeaking noise earlier was probably the belt starting to slip on the drum,replace the belt and drum glides when repairing,they are relatively inexpensive and as long as its torn down replace these too
Posted on Sep 15, 2010
My HL 2140 squeeks loudly when I turn it on as well as when it is printing
it most likely has parts that are worn out and need replaced. you will need to have it serviced.
Oct 09, 2012 | Brother HL 2140 Laser Printer
Thumping noise
Sounds like the tub is unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit before you get to the walled panels, and you are hearing a rubbing and thumping noise. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed.
Sep 18, 2012 | Frigidaire FEQ1442ES Electric Dryer
My maytag legacy dryer SDE305DAYW has a very loud squeeking noise when I start the dryer. After a minute or 2 it stops making the noise. Is this the belt?
While I would suspect the belt also, it could also be the drum bearing since they both could have the same symptoms. Suggest you try to turn the drum by hand and see if you can hear it then.
Aug 13, 2011 | Dryers
I have a 5 yr old KitchenAid front load dry that just started to make loud squeaking sound when running or even if I turn the drum when the dry is off. Drys clothing good, just making noise and want to...
You will need to check the tub roller wheels. This is a common noise when the wheel bearings start to ware down. They are not expensive, and you should be able to do this yourself. Good Luck Friend.
Feb 22, 2018 | KitchenAid KEHS02R Electric Dryer
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Sep 09, 2009 | GE Dryers
Dryer was squeeking now not spinning
It sounds like the dryer belt is wore out or broken, you can usually order a replacement belt from the maker of your dryer at there website.
Mar 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
My GE Profile Squeeks
Yes it still squeeks and it still drys and it kinda stops being so loud after the dryer has been drying for some time. Need help on solving this iissue and how to fix it.
Thanks,
Elaine Mohr
Nov 09, 2008 | GE Profile Harmony DPGT750EC Electric...
GE DCSR483EA Electric Dryer Logo
161 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
