Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
No power to the motor
When I turn the machine on (both red and black switches) the red heat light goes on but the motor does not. If I leave the unit unplugged for a half hour or more, the unit will turn on. If I turn it off and then try a few seconds or minutes, the motor will not turn on.
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Posted by jdw121 on May 16, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a thermal switch problem – when the machine gets too hot it will shut off to protect the machine until it cools off and then it will re-start or if it gets hot or plugged. The one light could be for the heater and the other could be for the motor, but it is a good idea to check with the customer service dept @ Bissell to see if they have a better solution and also check in the trouble shooting part of the owner’s manual. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 28, 2008
My Sebo X4 does not switch on, when powered up two red lights flash momentarily. There was a buzzing from the black box underneath but that has now stopped. I changed the bag yesterday as it said it w
Your red lights flashing momentarily is normal start-up. The fact that your servo motor is operating tells you that you are getting power. If the vacuum motor does not turn on, you likely have a problem with the motor itself or the power supply board that feeds power to the motor. These items should be covered under warranty. However, if your vacuum is outside the manufacturers warranty, you can replace either of these parts fairly easily with only a phillips head screwdriver.I have included a link to the parts list for this machine. We do stock both parts.
Sep 24, 2014 | Sebo X4 Extra Bagged Upright Vacuum
Replace motor
green is always ground. white or gray is always neutral. and black, red always hot. without know what make,model machine your working on this is best info i can give.
Jan 14, 2013 | Vacuums
No charge in Dyson, red light comes on instead
I'm sorry to hear you're having difficulty with your DC16. If the machine is displaying a red light, I'd encourage you to call us so we can run through some troubleshooting over the phone. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - please have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Dyson Online Customer Support
Jan 10, 2012 | Dyson DC16 Root 6 Bagless Handheld...
I have a clarke bench grinder model 1002. I have a light that I would like to attach into the wiring though the grinder wiring in it's base. The light has two wires, and the grinder has a ground that...
Attach the white wire on your lamp to the white wire on the grinder.
Attache the black wire on your lamp to the black wire on the motor side of the switch.
This will give the lamp power any time the grinder is turned on.
You can put a switch inline of the black wire to the lampp and it will allow you to turn it off when not needed
You can attach the white wires together and the black ones before the switch.
If you choose this way you will need a switch as the lamp will be power all the time.
May 21, 2011 | Vacuums
My oreck upright model xl3640 is not turning on. A clothespin was accidently vacuumed up, and the machine was immediately turned off to remove it. The bottom panel of the machine was taken off to remove...
the Oreck XL3640 power switch goes bad most vacuum service center can order a new switch it has 3 wires remove screws from handle to get at switch hook up wires to new switch color code of wires of wires are black white black just put on right terminal on switch _1284.jpg
Mar 08, 2011 | Vacuums
I have a broken chain switch that will not allow me to use all four light sockets. presently only using two sockets. Question: can I by pass the switch by combining all the black wires from the leading...
The blue should be for the lights and you can ty this into the black. The red should be the incoming for the motor to the fans. Some models are different and I strongly believe you have got to be talking about a ceiling fan and not a vacuum. Is this a test question? Because it is a darn good one if you do not mind me saying so however you might have not noticed to check or uncheck a box for the fans. Good luck.
Nov 02, 2010 | Vacuums
When I push the power button on my dc16 animal nothing turns on but a little red light by the red switch.
Hey Josh. According to the manual I found at this URL:
the red light that comes on when you try to use the unit indicates that the battery is fully discharged. When you plug the unit in to charge it, the same red light should be blinking to indicate the battery is in the process of charging.
Take a look at this and let me know if you are still having issues with the unit running, as there might be a problem with the wiring from the battery to the motor.
Sep 18, 2010 | Dyson DC16 Animal Bagless Handheld...
Electrolux Epic 2500 suction stopped
It could be the switch or could be the suction motor. Also, there is a thermostat on the motor that will shut it off if you don't have the air flowing to keep it cool. If that is the case, the motor will re-start after it cools down.
If the motor dosen't start, the cheepest way to start is to buy a new switch and install yourself. Just make sure where the wires go. The single terminal is to the front and the two terminals to the rear. The black wire goes to the front single terminal, the red wire goes to the far back terminal and the blue wire goes to the front back terminal. The suction motor should come on first and then the power nozzel. If not in that sequence,reverse the blue and red wires.
If that fails, take it to the Aerus/Electrolux shop.
Sep 01, 2009 | Electrolux Vacuums
The vacuum won't turn on. It"s an upright,and the power light on the on/off switch is lit, but no power to the unit below.
Check that you have power at the motor with a tester 0-200v .If you have it could be brushes or u/s motor.If not check power out from the switch ,if ok you you need to replace cables.
Please leave a positive feed back for me if this helps and get back to me if you need more help
Aug 09, 2009 | Oreck XL2200 Bagged Upright Vacuum
I had a loose wire in my Oreck XL motor. I took it
Lights are 12 volts.
The motor has taps on it to pull 12 volts rather than 120 volts for the lights, uses the motor as a transformer.
Should be black and white to the motor from the switch, believe the switch breaks the black wire. White wire should be neutral. I can't remember colors for the wires to the lights. Would expect it to be the white wire and then the "tap" wire to be red.
One crazy way to do it, is to hook up wires, leave the light bulbs out, turn on power, and check voltage at the bulb socket with a voltmeter. (This is one of those things they tell you on television to only let a professional do, do not attempt at home.)
Aug 07, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
165 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
