Boot fail - Computers & Internet
    Master:
    Sergeant:
  • 460 Answers
Pls refix your hardisk cables.After refixing it hardisk does not detect then hardisk has been faulty so it need to be replaced.
Posted on Sep 15, 2010
Boot failed
Is the optical drive a DVD drive?
Have you set the machine to boot from the optical drive?
Frequently the HP boot sequence is accessed by touching the Escape key on boot.
Dec 12, 2013 | HP ProLiant DL120 G6 Rack Server System...
When a SATA CD/DVD-ROM Drive is removed, the system fails to boot! Crazy! I just used the drive to re-load the machine but has to remove it. The moment it is removed, the machine fails to boot pas the...
Hi.
Go into the BIOS and set the BIOS configuration to its default settings. Save the changes and exit the BIOS.
When the computer restarts see if it will boot past the Windows logo.
Please let me know what happens.
Good luck.
Jun 09, 2011 | IBM ThinkCentre M50 8187 Desktop PC -...
Loading PBR for descriptor 2... MODEL DELL DV051
That is the boot loader message to boot to the NTFS Primary boot partition (Primary Boot Record for Descriptor 1 is the Utility partition)
Normally, this message flashes and the system boots, since it is not there is a failure in the boot process.
#1 run diags on the Hard Drive (CTRL+ALT+D at boot) and see if it passes
If it does
#2 Boot to you XP CD, press R for recovery console, and run the COMMAND CHKDSK /R see if the system will boot
If no go, go back to recovery console, try the command BOOTCFG /Rebuild then see if the system will boot
If That fails, try reinstalling Windows
If Diags Fail or all the above fail, replace the hard drive
Jun 24, 2010 | Dell Computers & Internet
Fail to boot
When you say boot do you mean POST?
Is it turning on at all?
What happens exactly when you press the power button?
Any beeps?
Open the case and remove everything except 1 RAM chip, the cpu, the cpu cooler. Hook up the monitor to the onboard graphics and try to boot again.
If it POSTs then you know that you have a problem with one of the pieces of hardware you removed, replace them 1 at a time until it fails to POST then you know which piece is defective.
If it still doesn't POST with everything removed, try a different RAM chip, if it still fails POST then you need to replace the motherboard.
Sep 16, 2009 | Intel DG965RY Motherboard
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
Not boot
my nokia 6670 doesn't boot gives message while power on "phone start-up failed " thnx 4 help
Sep 07, 2008 | Nokia 6670 Handheld
New memory installed in a HP Pavilion dv6000t Laptop-Booting Problems!
I have had bad memory straight out of the "box". Just becuase it's new memory does not mean it's good.
Take it back and get another stick.
Aug 30, 2008 | HP Pavilion dv6000z Notebook
Fails to boot
You might try a Hirens Boot CD, un-zip the files, create a bootable cd from the .ISO file and boot your troubled system, select virus scan on boot.
Apr 16, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
David Payne
David Payne
