I have a Maytag front load washer that moves and knocks around with items in the wash tub. It does not do this when nothing is in the tub. I have visually checked the struts and springs. They appear to be fine. HELP! HTH
  • tolenhilliar Sep 16, 2010
    Thanks for your comments. My problem occurs when the machine begins to agitate. The entire machine moves and there is knocking of the outer tub against the inside of the cabinet. Additionally, there is total movement of the machine. The machine doesn't even get to spin before it goes crazy! Since first posting the problem, I have exchanged the struts and stainless tub with substitute parts from another machine, but I still get the same issue. I have checked to ensure that the machine is balanced. I am ready to throw in the towel on this washer!
  • Washing Mach... Master
  • 909 Answers
There are 3 things that will cause this. 1)If you purchase a washing machine and the transport bolts are still in, 2)If your bearings are faulty it creates excess play and then goes out of balance when running, and 3) I think this is in your case, the wasking machine is on a very smooth floor like tiles etc. The springs arent able to do the job they are designed to do because the floor being slippery does not keep the machine stable. Suggest you cut 4 small squares out of soft rubber and place it underneath each foot.
Posted on Sep 16, 2010
  • 2,272 Answers
The "cleats" inside the wash tub are actually called "fins". If they are loose try tightening them to see if the sound goes away. You should be able to tighten them from inside the wash tub. Some models have mounting screws that are accessible from inside the wash tub.It could be sign that one or more of the mounting shocks under the wash tub could be bad, the rear tub bearing could be going bad, or the drive pulley could be cracked or warped.Remove the lower kick plate and watch the shocks during the spin cycle. The shocks should vibrate some, but should not be excessive to the point that it causes an unbalanced spin.
To check the drive pulley, remove the 3 screws from the washer top in the rear of the machine. The top should slide back some and then lift off. Watch the drive pulley behind the wash tub during the spin to make sure the rotation is smooth and even. Sometimes one of the arms on the pulley can crack or become bent and cause the pulley to wobble.And this can cause the noise.
If the rear tub bearing is starting to go, the washer will be very noisy during the spin cycle, and you may start to notice some stains on your clothes if the bearing seal has been breached. You can reach inside the wash tub with the unit turned off. With one hand, push up on the wash tub and release. If you can feel the tub moving up and down (even the slightest) this could be a sign that the bearing is worn out.Center Tub Nut if its loose then re-tight it.-------------
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 15, 2010
Why won't my washer spin?
Sounds to me like your washer tub had a very unbalanced load in it (heavy blankets, jeans, or pillows, all piled to one side instead of evenly distributed around the inside of the tub), and it threw it off balance. When it began to wobble and knock, it may have broken the mechanics underneath the tub which make it spin. The only way to properly diagnose it is if you remove the outer casing of the washing machine and look beneath the tub for broken/out of place items.
Feb 07, 2016 | Bosch Washing Machines
Maytag hav2558aww, made loud squealing noise upon the start of an agitation
Possible item caught between basket and outer tub. Remove the front panel and tub top ring. Shine a bright light around the semi-transparent tub and look for item. Check the pump pulley - ride the belt off and spin it by hand. If you feel any resistance or grinding replace the pump.
Mar 10, 2014 | GE Profile WPRE6150KWT Colossal Capacity...
I have a maytag mah8700aww washer,when it goes into spin,there a loud knocking sound
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer shaking very bad
It's very likely your washer is out of balance. The load has shifted and is not evenly spread throughout the tub.
Stop the cycle, open the lid, move the items around so they are more evenly distributed and that should solve the problem.
Oct 27, 2009 | Maytag LSE7806A Top Load Stacked...
Sounds like something is knocking around in the back of the washer. On the spin cycle, the noise is very loud anyway, but it sounds like there is something banging around inside. The drum moves around...
ok open the door
make sure the thing is empty
try to move the inner tub
if you can shke it side to side anything but around
you have a broken spinner support
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Squealing noise during wash cycle
yes thats a belt slipping may have something in the pump maybe a coin or a small item like that.
Aug 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Need to drain the tub before moving
It should all be drained out of there except a little in the hose. The sloshing sound you hear in there is not old water or stored up water. It is a liquid in a balancing ring that is sealed shut but it sounds like the water is in the tub. The best way to get all the water out is to take a wet vac and **** out the water from the drain hose. Just put you hand around the 2 hoses to kind of seal it and lay it on the floor. Nothing more is really needed to move it. Just don't be too wild moving it around lol. Front load machines are usually very heavy becuase they have cement or heavy pieces to keep the basket from moving around too much in a high speed spin. Good luck
Jan 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Found a white piece inside the back plate of washer
Hi rowdyg923
Nope, they are for shipping, they hold the tub inplace while it is being shipped. if they are left in when you use the washer it will end up wrecking it.
brent
Sep 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Removal of front assembly (Maytag MAH6500AWW)
remove the front ,everything thats in front of the tub.Remove the fins attached inside of tub ,remove any bolt you see .Remove the tub
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
