I recently had my capacitor on my a/c unit replaced and now it is just blowing out hot air the temp in the house reaches up to 89 with the a/c on auto run what is the problem
  • jamyla04 Sep 16, 2010
    Thank you very much!!! It was the fan motor that blew out also.
    President:
  • 1,515 Answers
Hi, I don't know what kind of unit you have, but I will go with a central heat and air. If its blowing room temperature air, the outdoor unit isn't running, or the compressor isn't on. You may have lost the run capacitor again. If you do have the outdoor unit, go look to see if the fan is running, and listen to see if the compressor is on and humming. If the fan is on, the compressor is off if you have no cooling. You can remove the control panel if you are inclined to do this, and you know the dangers of electrical shock. Turn the breaker off first, and look at the capacitor to see if it is swollen up, leaking oil or deformed. If so, that's the problem. This would be the first part to replace. You may have lost the compressor also. You do need to check these things, breaker, fan, compressor as this is what gives you cooling along with other parts such as the condenser motor, and check the run capacitor Please keep me posted by leaving a comment I can check, and please rate me on this as I know you will be kind. Get back to me so I can help you find the problem.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 15, 2010
Testimonial: "Thank you very much for the advice. It was also my fan motor that blew out."
  • Robert Horton
    Robert Horton Sep 18, 2010
    Thank you for the awesome rating. Some times the motor goes bad and this is why the capacitor blows out also. That's normally the sign of a motor going to fail, is the capacitor will fail first. I am glad you are up and running.
    Shastalaker7
Amana Packaged Gas Unit Not Blowing Cold Air
There may be a capacitor on the outside of the compressor that needs to be replaced. You would have to take it apart to see.
Jun 04, 2013 | Amana Heating & Cooling
We have a Brisk Air in our 1991 Jayco Eagle. The travel trailer is from Rhode Island and we're not sure if the air was ever used. The unit turns on, the compressor engages but doesn't blow cold air, only...
Really sounds like the compressor isn't coming on. Go on top of camper and take the housing off. Now then engage the air conditioner and feel the compressor. Touch the copper lines to feel any temp. change. Now then if it isn't coming on look for the capacitor. Silver looking can that is the item to check. They are duel purpose they run the fan and the compressor. Unplug the electricity and remove the capacitor remembering the wires and were they went. Now take to parts house and they will be glad to check it. Should only cost about 15 bucks for new one. Get the same rated size. be good to go. ken
Sep 15, 2010 | Dometic Rooftop RV Air Conditioner
CLJ42-1A blowing hot air where is the capacitor located on unit?
The capacitor is located inside the access panel on the unit. It should be attached to the housing within. These are fairly cheap if you replace yourself, just be sure to get the exact same micro-farads that the used one has. Also remember that a capacitor stores electricity and the terminals should be grounded before replacing.
Aug 15, 2010 | Goodman CKL36AR36 Air Conditioner
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
Not cooling house. Its never worked.
Check and see if the inside and outside coils are cleaned , if they are , have someone come out and check the freon in the unit it can leak out over a period of time.
Jul 20, 2009 | Weather King 10PJA2501AH Air Conditioner
Central air unit problem.......It starts out blowing cold then will only blow room temp air after some time. I don't see anything freezing up..Filter is clear. The unit outside is not clogged up. The...
Check your outside unit to see if fan is running. If it is running check to see if air is blowing out if not you have a bad capacitor. Some times if a capacitor shorts out the fan will run backwards and the line will get very hot same as if the fan is not running. Russ
Jul 20, 2009 | Heating & Cooling
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
Hot air
Sounds as if a Capacitor has failed. You must remove the face plate of the unit and find this capacitor. It will be gray in color, oval and have 3 terminals on top. Take this to a supply house and get another with the same ratings. This is important! Replace this and your problem should be solved. Remember to replace the connections as before.
Nov 07, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
