Question about Bosch Washing Machines
How do i remove compartments on indesit moon to clean them. Mine are very gungy . Ive cleaned the bottom one but cant figure how to do others
  • 1294 Answers
SOURCE: Filter on indesit washing machine
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Posted on Dec 01, 2007
SOURCE: Remove the fabric softener compartment for cleaning
i cleaned it then when i use fabric softener i also add a lot of water
i have a bottle of water sitting on my dryer for this
Posted on Mar 09, 2008
  • 1462 Answers
SOURCE: Indesit wil 103 filter
stale smell may be due to using liquid detergent - change to powder.
filter may be of two types. if in the front, unscrew cap and just pull. may be difficult is a foreign object like a bra wire is stuck inside.
other type of filter is in the large diameter pipe from bottom of machine to pump. take off small back bottom panel and undo this pipe at the machine end and filter is inside this pipe. pull out and clean
Posted on Sep 04, 2008
  • 958 Answers
SOURCE: Removal of washing machine soap dispenser - Indesit
hi sue,
i've check the web and i found thatt you just have to pull the soap dispenser towards you. if some clips are rising when you pull it, gently press it down and continue pulling it.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
  • 236 Answers
SOURCE: fabric conditioner compartment doesnt empty
If you can remove the dispenser from the machine try soaking it in HOT water. The fabric softeners can cause a wax like build up that can clog the dispenser. If the dispenser will not come out of the machine then pour Hot water into it, cycle the machine and repeat. It took a long time to clog and will take a while to remove the clog(several cycles). This will work but will take time. Mix water with your softener to keep it from cloging again, it will thin the softener and stop the build up. If you add 50/50 water/conditioner shake well and use twice the normal amount so you are getting the full amount of softener/conditioner into the washer. This will help i had a similar problem with my front loading washer.
Posted on Oct 17, 2009
Iwd71250uk fabric softener staying in dispenser.
Compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow the grid.
Cleaning the detergent dispenser drawer
Remove the dispenser by raising it and pulling it out (see figure below). Wash it under running water; this operation should be
repeated frequently.
25825864-ineink0kisfnom0atbkujjcx-3-10.jpg 25825864-ineink0kisfnom0atbkujjcx-3-3.jpg 25825864-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Aug 17, 2015 | Indesit Washing Machines
Tumble dryer eeps tripping electric
Had same problem found a lot or water at the rear of the condensing element at bottom front of dryer because the float at the rear was blocked with fluff resulting in water being flicked up by the fan onto the heating element and tripping the electric. Cleaned out float compartment and been fine up til now. For a quick fix (UNPLUG FIRST) remove the condensing element at the bottom front of tumble dryer(behind the drop down cover) then carefully tip the dryer forward and to the left so that it practically balancing on the front left corner, you will probably get a fair bit of water come out so have some towels ready, then dry as much as you can see inside the compartment then replace element and should be good for quite a while until you have more time to clean out the rear compartment. Hope this helps, let me know.
Feb 11, 2014 | Indesit IS70C Electric Dryer
Cannot open filter on indesit moon
Hi there
The filter is usually at the front of the machine down at the bottom
There you have to loosen a ca 5cm piece of metal. It usually opens like a small shelf, the you look for a round bit of plastic that you can turn clockwise do that very carefully. There can be a lot of water there behind the filter. I usually have a lot of towels on the floor to take the water as it comes out. You never know how this works the first time, after that it is easy. you take the filter out, clean it.. Put it back in.
Leave the machines brain to rest for awhile then you will be able to open the door.
good luck
kolbrun
Apr 06, 2012 | Indesit Washing Machines
My indesit front loader WG623 is not emptying the softener compartment . I have removed and cleaned the soap and softener comparntment properly...
Thoroughly clean the top of the soap drawer compartment with a stiff brush or similar, poke a piece of wire into each individual hole in the top of the compartment.
Make sure the the syphon tube is not blocked in the soap drawer.
Nov 02, 2010 | Washing Machines
Dose not take conditioner from draw on rinse cycle
Remove drawer from dispenser housing, and thoroughly clean all parts of it, removing any pieces inside the drawer, and again clean thoroughly.
Check to see if the sypon tube is clear in the conditioner compartment.
In the top oif the compartment, look to see if you can see any holes, and poke them clear with a piece of wire or similar.
This should solve the problem.
Dec 14, 2009 | Indesit Washing Machines
Where is the oil filter on a Yamaha XT 125?
If I recall correctly, this bike has a centrifical oil "filter". Not really a filter as commonly refered to but rather a hub about the size and shape of an eggshell cut in half. Oil flows through the filter and centrifical force forces heavy particals to the face of the hub. Particals build up on the face and are thus "removed" from the oil supply. This type of filter is usually on the end of the crankshaft. To clean the filter just scrape away the soft buildup and put the engine sidecase back into place.
Mar 11, 2009 | 2007 Yamaha XT 125 R
Hi i have an indesit wd12x washing machine that does not drain the water. How do i get to the filter to clean it? Thanks
Your model of washer dryer is fittted with a self cleaning pump, and may not have a filter fitted.
To check if it has, remove lower plinth at bottom of m/c, and if there is a plastic panel there ,remove that as well.
If there is a filter fitted, you will see it at the bottom right front, it has a round cover, unscrew anti clockwise, remove and clean filter.
Pleas leave a fixya rating if you consider my solution appropiate to your query.
Thankyou.
Jan 29, 2009 | Indesit W 123 Front Load Washer
Compartment 3, detergent dispenser, fabric softener.
Grasp the drawer firmly, and give it a good tug to pull it out.
Remove all parts, and thoroughly clean, then just line it up with compartment and push it back in.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Indesit W 123 Front Load Washer
Sep 04, 2008 | Indesit W 123 Front Load Washer
INDESIT Washing Machine
Probably the pump or hose is blocked, remove the cover along the front bottom, of the machine, remove the filter and clean out, ensure the pump impeller is clear of debris and rotates freely.
refit the filter and try again.
Apr 18, 2008 | Washing Machines
Washing Machines Logo
78 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
