Question about Bulova Watch
How do i change the time on a speedo 'spirit' watch?
Hi, i changed the battery of my sensor but it doesn´t work now im desperate. Do you now what it could be?
Could you have put it in the wrong way round?
Try removing the battery and cleaning it with surgical spirit or a similar de-greasing agent.
Replace it carefully, avoiding finger contact with the conact points, (hold it with a paper towel perhaps).
Sep 14, 2010 | Polar Electro Wearlink Coded Watch
I have the Speedo Kids Active Swim Watch and cannot remember how to turn on/off the alarm and set the alarm. Please help!
You might find this pdf helpful - it gives a basic description of how 4 button watches can be set.
www.buydakotawatches.com/PDF_FILES/Digital.pdf
Sep 10, 2010 | Watches
My lady's Armitron watch works perfectly. However the watch band which permanently adheres to the watch case has caused my wrist to break out where the clasp closes. this irritation has caused severe...
I suggest you try a self adhesive plastic or baise material. Clean the back with surgical spirit or methylated spirits before attaching the material.
Aug 07, 2010 | Armitron Watches
Need help setting time etc on my pro spirit watch from Target
I searched for instructions for you watch but was unable to fins them. If you follow the instructions below, you may (with some experimenting) be able to set your watch.
There should be a button marked "mode". Pressing this button cycles the display through the various setting options that are available on the watch.
The functions are likely to be abbreviated, so you may have to guess what each one means.
When you have reached the time setting mode (TS perhaps?) use one of the other buttons to advance or ****** to time etc.
Good luck.
Feb 20, 2010 | Watches
My Fossil watch worked when I took it off, it just needed a new battery. Now, I tried to replace the battery, and it won't work
Check that the battery is in the correct way up.
Try cleaning the battery with surgical spirit.
If these steps fail, take it to a watch shop.
If this also fails, find you nearest Fossil dealer (Fossil/customer care - store locator
Feb 11, 2010 | Fossil AM3784 Wrist Watch
The watch is not running after replacing the battery, the stop watch part is running.
It could be that the battery has a poor contact. Try cleaning the battery with surgical spirit and avoid handling its faces.(hold the edges).
Clean also the watch contacts.
Feb 03, 2010 | ESQ 07300902 Wrist Watch
I NED AN OWNERS MANUAL FOR A PRO SPIRIT
You can get setting instructions from their web site "citizen.com",
When you get t the site, click on "technical support" (on the right of the screen) and then on setting "instructions".
Fill in the requested details and the click on "get setting instructions"
Jan 27, 2010 | Citizen Watches
Picture glued in old gold pocket watch
If its a valuable pocket watch in may be better not to remove it. If not try either a little water and allow to soak to soften or metholated spirits.
Jul 15, 2009 | Watches
Need to set the time on a Pro Spirit watch
http://www.nsftools.com/misc/TargetDigitalWatchInstructions.jpg
Apr 13, 2008 | Watches
Bulova Watch Logo
99 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
